If someone has has a few minutes, I'd like to confirm that my Mini auger on/off times are correct. I'd like to know the measured on and off times for both heat level 5 (Hi) and level 1 (low). Please note down the Feed Rate Trim setting (which light is NOT on when pressing the Feed Rate Button.
Backstory:
I upgraded my Mini to a Mini-A control board a few years back, along with newer burn pot. My control board, model 50-1929 is configurable for many feed rates to match many models of stoves. The configuration instructions are not so clear, but I do think that it set for the "default" which should cover the Mini. By comparing someone's measured numbers to what I get, I can confirm that I'm not over-firing.
See p
icture of control panel
Thanks -
Backstory:
See p
icture of control panelThanks -
