John, thank you for posting your pictures. It's surprising such a small sized unit could dheat the amount of basement space you have. But I suppose its about the same size of a water to air heat exchanger I've over my furnace that heats 3000 sq, feet. Coincidentally, I found a calculator on the Modine site that figured out for my application that I'd need the same sized Modine as yours to heat my shop when the outdoor temperature is at zero degrees F. It rarely gets that cold here in the western part of Virginia. I'll have to fine tune the calculations to allow for a worst case scenario of water temps in the 140 degree range, but this looks promising. Supply House (formerly Pex Supply) carries that unit so ordering would be simple too.
Do you have a separate pump supplying it's hot water? I don't imagine a hydronic Modine comes with its own pump. If so, would you mind sharing what size or kind pump you have supplying hot water to your Modine? I promise no more questions. You've already been very helpful John. I think this might be a lot simpler installation than a separate w/a hx and air handler. Thanks again,
Mike
Mike
, I think you would only hear it in the shop if your other stuff isn't running. The photo I shared shows the heater sitting right under the floor of my Livingroom. If it is running you can pretty much only hear it in the Livingroom and barely noticeable when the TV is on. I had it installed when we replaced the oil boiler with a propane boiler (before we had the wood boiler) and would run it regularly to keep the basement warm for the kids. With the wood boiler and storage in the basement I really don't need to run and if I run it with the low temp water that I use it runs for longer periods of time. Basically it became an annoying noise/vibration to pick up 2 or 3 degrees in the basement. I often think of the hard life my parents had and shake my head thinking that this noise issue is the biggest thing I have to complain about - its a good life.
