What are they asking for the stove?
A cat stove will burn at a low rate cleaner than a conventional stove. This is good for milder weather and climates. The Dutchwest 2461 (large) is rated for up to 1600 sq ft.. The Extra-large is rated up to 2400 sq ft. I think the 2461 is the right size for your spot if you live in New England. A Woodstock Keystone is another cat stove that would work well.
This is not the only stove that will work there are a lot of ~ 2 cu ft cat and non-cat stoves out there in cast iron, steel and soapstone. To make better suggestions tell us more about the house. What height ceilings? one or two story? open floor plan or smaller closed off rooms?
The area heated ratings are the maximums not the minimums. The 2461 is 1.6x your area. The minimum is set by how you control the fire and how often you heat. In mild weather you might just have a small evening fire and let the stove go out. Cat stoves usually are able to extend burn times due to the ability to burn a low fire cleanly. They don't produce more heat. When it is cold out and the stove is being pushed the cat has little advantage.
How tall will the chimney be that the stove is connecting to?
That gets more tricky. There needs to be no air leaks below the stove thimble. That means no other open takeoffs and the cleanout door is gasket sealed tight. There is a huge difference between 10 and 15 ft. which is it? Most modern stove are going to require 16'. Introducing a couple 90 turns reduces the draft, so the chimney may need to be extended if draft is poor.
Sounds like you are referring to another thread. That gets confusing for my late at night brain.
If it is an 8x8 tile lined chimney in very good condition you may be able to install without a liner. That said, a full liner sized to the stove is going to provide the best safety and performance.
Definitely add a stainless liner to connect the stove to. It's better to save lives than money.
Measure up the ID of the interior flue passage. And figure out the distance between the hole and the top of the chimney. Then look up chimney liner kits at Rockford, ChimneyLiner Depot, Northline Express, etc.. You may be able to drop a rigid liner down if all is clear with no mortar blobs and well aligned. That's a nice way to go if it will fit.
http://www.rockfordchimneysupply.com/
http://www.chimneylinerdepot.com/
http://www.northlineexpress.com/chimney/chimney-pipe-stove-pipe/chimney-liner.html
