I have a new addition I installed over my attached garage and I'd like to install Radiant Heat in this new area (destined to be a bathroom). I don't necessarily need to rely on the radiant floor to "heat" this area because I have forced air but because of the unconditioned space below and the fact that it will be primarily a ceramic tile surface I know the floors will stay uncomfortably cool in the Winter if I do not use Radiant.
I currently have a Solar hot water heater for DHW and I think I will try to use that as a heat source -- again just to moderate the floor temp. I'm sure it won't supply enough hot water and will require electric backup but in the future I'd like to install a Wood Boiler and retrofit my whole house with a combination of radiant floor, baseboard and wall mount radiators. One task at a time though... Even if using my DHW as a heat source proves unsatisfactory I still want to install the radiant loops in this area because once the tile floor goes in it will not be possible to go back and add radiant loops latter (I don't have access to the underside of the floor).
I'm hoping I can install on top of my sub-floor with what I've seen referred to as radiant sub floor board, I'd like to keep the height increase to a minimum but I've already accepted that I'll probably have to re-frame my door ways to allow for the increased height of the floors. My drywall isn't in yet but will be soon so I only have a couple of weeks to work this out. If I had thought ahead I could have used a product like Warmboard for my subfloor but I didn't
I've done a Heat Loss but just not sure what to do next and thought I post here for help:
-How do I use my heat loss data to design the floor layout. For instance how do I calculate how far to space my loops etc.
-Any Internet sources for radiant subfloor board? I can't seem to find a supplier in my area (central MD). What are the alternatives?
-If I install a Wood Boiler in the future with the intended purpose of supplying a mixture of radiant floor and baseboard or wall mount radiators zones, how do you regulate the temperature between the two? Radiant floor has a lower temperature requirement correct? I'm assuming you don't want to pump 170-180 degree water through your floor. I guess you can use the return leg of a radiator zone to supply the floor zone but what if you want to keep the two zones independent? If you have a storage system holding 170 - 180 degree water I don't understand how you bring that temp down to 120(?) degrees to supply the floor zones. I know there are such things as mixing valves but where is the cooler water coming from to mix?
-How far should radiant lines be kept from the wax ring of a toilet base?
Thank you.
Thank you.
