We are building a new house and our builder is just about ready to get started on our hearth for our woodstove.
The stove is heavy (465 lbs) and requires a minimum R-Value of 1. We are good on the size requirements, but unsure of the construction methods and materials.
We will be starting on top of our OSB sub-floor, and were thinking of using 2x4 metal studs for air-space, then a layer or two of durock, and the top layer of brick or Owens Corning Hearthstones.
I have heard you guys talk about putting a layer of sheet metal down before and/or between the durock... why? To keep the stove legs from busting through the durock?
Is the layer of latex-fortified portland cement also required between the layers?
Will the durock support the weight of the stove and the pressure from the stove legs with the studs placed on 16" centers?
THANKS
THANKS
