Some of you may remember my thread a little while ago about removing our Freedom insert, and replacing it with a pellet insert. I been thinking a lot about this, and I don't think I want to limit myself to a single fuel. With that in mind, I would like to remove the insert and install a Lopi Cape Cod. A BKK would be nice for the long burn times, but SWMBO can't get past the utilitarian look of it.
So to install the Cape Cod it seems I would need to remove a couple of courses of brick from the masonry fireplace to raise the lintel height. This would give the added benefit of allowing the stove to sit back into the opening more so it doesn't protrude into the room as much. I would definitely go for the optional fan in this setup since the stove would be semi-recessed.
So, how hard is it to raise the lintel? Is this something I could do myself, or would I need to hire a mason?
Thanks,
Mike
Thanks,
Mike
