ok... after a few years of burning and doing all modes I finally gave up the ghost and found stove[constant] to be the most consistant for steady heat that keeps the thermostat in the main living area spot on same temp.
this of course when temps are going to be no higher than 30 degrees..
room/auto works well on those days the temps will jump in the afternoon as we gets lots of sun facing us.
I always stayed away from stove mode since it's understood that it uses more pellets. . with a steady heat flow I can lower my temp and fan speed a bit so not really using that much more. I'm going to use 3/half to 4 tons each year regardless...
many say they use room/manual mode but my problem with that is there are periods of time that the distribution blower shuts off [as it should when temp is reached] in maint mode but 10- 15 minutes or more of heat just going up and out the exhaust pipe to me is a waste..stove modes fan never shuts off.... also, running manual just to save the ignitor is not reason enough, I have changed them and it's ezpz... at least with room/auto the dist blower squeezes out every bit of heat it has till it ramps down and at times shut off.
one other note and this I think is Key:
we have a not well insulated house and it can cool down very quick so we can lose heat quicker .
stove mode keeps it steady all the time..[we burn 24/7].. But, if your house is tighter than a babys Butt
stove mode may end up being a bit too hot after a while and manual may be better but still, sending heat out the exhaust and Not into the dwelling while the dist blower is off in any mode is questionable...... my 2 cents.......
