Sure, the Woodstocks I've run have been pretty much foolproof. But my Buck 91, on a 22' interior stack, demands that you take some variables into account. The only cat stoves with 'training wheels' are the BKs, with their thermostats.it's definitely a learning curve to dialling in a baffle/reburner type of stove. It takes some practice and skill to run one well, not like those cat stoves that even a small child could operate.
I think you already got the answer on this. If you want to discuss further, we can start a separate thread and link back here.But as I think of it. my problem isn't necessarily overheating the house. I feel the problem would be with any type of stove. I can certainly get the stove running at lower temperatures, a more ideal temperature for these mild weathers, but whether it's a cat or non-cat stove, isn't running the stove at say 200 degrees going to be an issue with creosote buildup?
So, you're finding that running the fans cools the stove to the point where your thermometer indicates you may be killing secondary combustion. First, I'd try to determine if that's even true, and one of our non-cat experts can surely help you figure that one out. Second, short of killing secondary combustion, fans have very little impact on the efficiency of a stove (meaning fraction of heat into house versus heat up the chimney), in most standard installations. The exception to this rule is when the stove is very near a masonry structure (eg. your fireplace), where the fans may be increasing convective coefficient, and thus reducing the heat radiated off the back of the stove into the masonry. In my house, I have to run fans, or I'm putting half my wood into heating the back yard. Others with well-insulated stick-frame houses see no benefit at all, in their installations.I can get the house to where I want it to be by turning the fans off, but I feel like I'm wasting the heat generated from the box if I'm not pulling it all out.
That's not training wheels, it's cruise control.Sure, the Woodstocks I've run have been pretty much foolproof. But my Buck 91, on a 22' interior stack, demands that you take some variables into account. The only cat stoves with 'training wheels' are the BKs, with their thermostats.![]()
Gotta do a better job of looking back then asking again though. My bad!So, you're finding that running the fans cools the stove to the point where your thermometer indicates you may be killing secondary combustion. First, I'd try to determine if that's even true, and one of our non-cat experts can surely help you figure that one out. Second, short of killing secondary combustion, fans have very little impact on the efficiency of a stove (meaning fraction of heat into house versus heat up the chimney), in most standard installations. The exception to this rule is when the stove is very near a masonry structure (eg. your fireplace), where the fans may be increasing convective coefficient, and thus reducing the heat radiated off the back of the stove into the masonry. In my house, I have to run fans, or I'm putting half my wood into heating the back yard. Others with well-insulated stick-frame houses see no benefit at all, in their installations.
I will add that the good dry wood is not just a requirement for the reburner/tube stoves. I cleaned a BK King cat last week that's chimney was creo'd up like no tomorrow. I'm sure wood was an issue because he was buying out of the classifieds and burning it straight away. Not saying user error wasn't part of it too and not trying to totally derail your thread.
I'll use my IR gun tonight, like Begreen suggested, and see what sort of readings I get on the front part of my stove,similar to where your thermometer is placed on your summit insert. So we can compare a bit more.
I've only been diving in here so much because I have the exact same model(as a freestanding stove) and would like to see you get dialled in to some good and safe burning.
Maybe save the current wood supply for next season and see if there is good, kiln, or shed dried wood sold in your area?
The heat is only "wasted" if it's going up the chimney, either in solid particulate (potential energy) or heat (kinetic energy) form, and I don't think that's your case. Burning hot might deliver more heat than you desire, but it's not wasted!I'm definitely noticing more and more that if I'm not feeding my stove with dry wood, it's gotta have completely open air flow for far too long, wasting way too much energy. I think it was begreen who mentioned that even if you can get a few pieces of dry wood in there along with the 20-25% wood, it will make a noticeable difference.
If you have a woodlot and a saw, and can find small, dead-standing trees with no bark, a lot of that will be around 20%. Those small ones start adding up to a decent amount of wood if you can find several...if you can get a few pieces of dry wood in there along with the 20-25% wood, it will make a noticeable difference.
Wood can/will burn (ignite) at 425*-450* (F)...wood that has been baked (pyrolosis) (SP?) will ignite as low as 190*Last winter we only had green wood for heat. I put a hearth grate on top of the stove and baked a stove load of wood.
Reloading the grate each time we loaded the stove.
WE went from foaming sizzling wood that barely burned, to wood that lit instantly and burned hot (maple)
We really got to like the smell of baking maple wood, and all the evaporated water from the wood went into the house instead of wasted up the chimney .
IF YOU TRY THIS
You have to keep the top of the stove clear of chips and scraps or they char and make smoke. we used hearth bellows to clear them.
Don't let any wood touch the stove or it will burn, I laid gas stove grates on the stove to keep any wood contact from happening.
My infrared thermometer showed that the wood on top never got over 300 F.
I'd add that I'd not try this unless you're going to be near the stove for the entire duration. I'd definitely not be comfortable leaving the house, with a load of wood baking atop the stove, no matter how many times you did this without incident.IF YOU TRY THIS...
my wife is a home maker, and homeschools the kids, someone was always in the room.I'd add that I'd not try this unless you're going to be near the stove for the entire duration. I'd definitely not be comfortable leaving the house, with a load of wood baking atop the stove, no matter how many times you did this without incident.
Random question #13027.
How much would a single rainfall impact uncovered seasoned wood, and do you need to bring to a sheltered area for a few days before use to dry out again?
I find that temperature hard to believe considering that paper must be higher than that to ignite .Wood can/will burn (ignite) at 425*-450* (F)...wood that has been baked (pyrolosis) (SP?) will ignite as low as 190*
I did too...and unfortunately I can't seem to find the resource where I found this info. Now mind you this is not just any piece of wood, like I said, this would be after significant pyrolysis...which can lower the autoignition temp to almost unbelievably low temps.I find that temperature hard to believe considering that paper must be higher than that to ignite .
After all, you can boil water in a paper cup if you are careful
He is right I will try to find the info but I know it is right. Drying wood on top of a wood stove is a very bad idea. I don't care how many times you have done it it is still a bad idea.I find that temperature hard to believe considering that paper must be higher than that to ignite .
Thank you, that was one of the articles that I had read...I was off on the low temp ignition though...170*F, not 190"Wood can/will burn (ignite) at 425*-450* (F)...wood that has been baked (pyrolosis) (SP?) will ignite as low as 190*"
Here is one reference I have seen related to this.
(broken link removed to https://www.doctorfire.com/low_temp_wood1.pdf)
I'm not arguing that it has been done successfully, I'm just making people aware of pyrolysis, that in general it is not a safe practice to bake wood on the stove, and that wood can and does ignite at a much lower temp than most would think sometimes.That link says less than 250C for years, I'm talking about 2-4 hours on maple cut with green leaves on it.
Baking wood is actually an old idea from back when you had to have a wood pile as big as the house to make it through the winter... hard to get ahead that way and keep the farm.
