Rear or Top exit
[email protected]
102
I have a Coalbrookdale Much Wenlock coal stove. it is set up for rear venting. I would like to switch it to top venting and it has that provision. However, it seems that whoever set it up for rear venting sealed the seams on the bayonet type locking mechanism with cement. I can't budge it. Is it a lost cause, or is there some trick to freeing it up ?
Thanks
JM
If you can't gt at it from inside, outside, with screwdrivers, with pb blast, thent here is only one answer. Heat it up, or hit with a sledge(gently). Onthe other hand, I'd wait for someone who has seen one of these before, as there may be a trick to it.
