So I've had issues with the fans in my Heat n. Glo North Star unit (in other forms, Heatilator Constitution or Quad 7100 and I believe they fit many other models of hearth&home fans, and most other units will be extremely similar anyway). They start making some eery noises, but mostly they just start getting loud. It's just the bearings in them, I'm going to surmise.
I had 2 sets of these fan units replaced while it was still under warranty, but now it's out of warranty and they want upwards of $175 which is what you have to buy, the entire fan assembly complete with motor, bearings, housings/squirrel cages etc.
One set was getting loud towards the end of last year, I turned it on just now, yep, it's a noise maker. The fans are kinda a low background noise, while I'd rather not have it, they are necessary for this unit to heat the house, but if they're working right, you mostly don't notice it. But when they start acting up, it's a downright annoyance.
So, I took one apart and will order some new bearings for them. These have 608 metric bearings in them.
8mm Shaft, 22mmO.D and 7mm thick.
The fans come apart fairly easily, small pinch clamp holds the squirrel cages onto the shaft, remove clamp, pry up on cage from bottom and it comes off. 4 small hex screws hold the metal housing onto the motor brackets, and then 2 long hex screws hold the motor brackets onto the motor. Once the motor brackets are off, you can slide the motor axle out with the 2 bearings and the motor rotor. Then simply pull the bearings off the shaft. I have a bearing puller, but they're not on the shaft all that tight, but you'll need to pull the bearings off.
So I ordered some replacement bearings from McMaster-Carr. The ones on the unit are double-sealed, so I ordered those. You can get in either steel ($5) or stainless steel ($13). I suspect due to the harsh environment in which these live, lots of small fly ash, heat....it's the reason they fail fairly quickly. If these new ones fail quickly, I may just try shielded or even open and just clean and lube them periodically. Mabey..we'll see.
Anyone replace these bearings before? Figured I'd try it before I spent $350 on new fans.
![[Hearth.com] Rebuilding blower fans... [Hearth.com] Rebuilding blower fans...](https://www.hearth.com/talk/data/attachments/165/165726-21a6def06453b54d8b9da5b01f5a2a94.jpg?hash=QYZvvcUvYn)
![[Hearth.com] Rebuilding blower fans... [Hearth.com] Rebuilding blower fans...](https://www.hearth.com/talk/data/attachments/165/165727-0f0896513b7a3f9a462cb41bc35256ed.jpg?hash=P-aJa4NecE)
![[Hearth.com] Rebuilding blower fans... [Hearth.com] Rebuilding blower fans...](https://www.hearth.com/talk/data/attachments/165/165728-7dd9bf617d4582d010db5ca19dc060af.jpg?hash=tpNfGuoXik)
