Hi All - My wife and I recently purchased a house, and we would like to buy a wood stove or wood stove insert to help heat the house. A little about the house. 30 year old house, 3100 square foot colonial. The existing fireplace is on the first floor in our great room, which has a vaulted ceiling (with ceiling fan) and is partially open to our kitchen and four season room. Our family spends most of our time in those three rooms. The rest of the first floor consists of an office, dining room, living room, and laundry room that are a little further away from the fireplace. There is a two story foyer and open hallway upstairs that looks down on the foyer, and this foyer shares an adjacent wall with the great room. There are four bedrooms upstairs. The primary heat source is forced air electric via heat pump and electric resistance furnace for when it is really cold. This is the heat source primarily because the town I live in has a municipal electric company with great rates so it is common to see this. Rates have gradually increases over the years, and it is not as great of a deal as it once was. I'd prefer to have a second source of heat and offset some of the cost during winter heating season. I have access to as much free hardwood as I am willing to cut. OK, so enough background, here are my questions:
1. I'd like to assist the heat in getting circulated in the house. My furnace fan can be set to run continuously on low to move air even when it is not calling for heat, but my cold air return is at ground level in the great room. I am thinking of trying to locate that return higher up on the wall to capture that heat to move throughout the house. The second thing I was thinking is to install a small fan through the wall that is in between my great room and the two story foyer to help move air to the upstairs hallway. Do you think either of these strategies will be effective or am I going to be fighting a losing battle to get this heat spread throughout my house? Basically, I am looking for suggestions on how to produce as many BTU's out of this wood insert and distribute it without cooking us out of our primary living space where the stove is.
2. I'd really like to operate this stove as much as possible, and long burn times are certainly a method of accomplishing this. I've read quite a bit on the cat vs. non-cat stove debate, and clearly understand the benefits of a cat stove on long (but lower heat) burns. My concern is that if I go too low on the burn temps I am not going to get enough heat to really make much difference on a house of this size and configuration. So if I am trying to get true 8-10 hour burns of medium heat, does that eliminate most of the cat benefits, and should I just be trying to shop for the biggest insert I can fit with a decent secondary burn system and call it a day?
3. I have always burned wood, but am also considering a pellet insert if it offers enough benefit over a traditional wood insert. If we placed heat output and ease of use higher than the ambiance of a traditional fire, should we look at pellets as an option? I can cut as much wood as I need, and it is free, but I could easily sell this firewood to buy pellets if the benefits are there.
Thanks in advance for any guidance you can provide!
