Was that in Troy? I took a tour of the place a couple years ago.Here is a pellet boiler built in upstate Ny for 30 psi operation. It takes a lot of stay rods to build a square or flat surface pressurized vessel. this is a stamped vessel.
A stupid question: Your storage is unpressurized, is the boiler pressurized and giving up its heat through a heat exchanger in the tank? Does the water in the tank flow directly through the distribution piping with no heat exchanger? I'm just curious.I elected to go with non pressurized storage. It takes up less room and was a lot easier to haul home, carry down into my basement. and install. Since the storage water never gets changed and the heating water never gets changed corrosion isn't an issue. The life of the PVC liners appear to be quite long, there were some experiments with other materials, like EPDM that have been less successful.
So, the boiler and distribution could be closed and under pressure this way? What does this exchanger look like? They used to be big coils of copper, no?We use a single heat exchanger to input and remove heat from our tanks.
All our heat exchangers are now stainless steel.
I have done systems without heat exchangers, but the systems should be non-ferrous. Dick Hill and I had done systems that were without hx and were ferrous but we dosed them with some heavy duty corrosion inhibitors. Garn does this but it does warrant ongoing testing.
and only light one 3 to 4 hour fire per day. I always check the temperature just before lighting the daily fire. The circulator launch temperature is 187 degrees but shortly after launch the tank temperature will drop about 2 or 3 degrees.I am looking to possible add pressurized storage to my system and space is limited .Does anyone have experience with rectangular tanks like this one. (broken link removed to http://newhorizonstore.com/Products/96-tank-hot-water-storage.aspx)
Perg,
I have that exact tank that I bought from new horizons. I'm on my 5th heating season now and haven't had any problems. I don't believe it is ASME certifified but I think it's rated to 35 PSi.
Oh, please tell us more.No way is that tank rated to 35 psi and it definitely isn't up to ASME standards. Knowing the source I doubt it has any legal rating at all. Not saying it's not a decent tank, but pressurizing it beyond 5 psi would be a risk I wouldn't take.
When installing the system this seemed like the simplest way to go for someone with limited brain power. I also only distribute heat from the tank so the actual "heat making" portion is about as simple as you can get. It has served me well for the past nine yearsFred, I thought you were circulating the boiler water and the dhw through heat exchangers and the tank water was isolated from that?
