My hearth had some ugly plain white tiles that I removed down to the concrete sub hearth. I will put new tiles over it or maybe a single slab piece but ideally I'd like to have the finished surface flush with the surrounding hardwood floor.
The concrete sub hearth currently sits just slightly above the floor level. From the basement I can see that the sub hearth is wedge shaped and one test hole told me even towards the edge it is more than 2-3 inches thick.
What I want to know is whether I would be opening up a can of worms if I just got Bull Dog Hammer Drill to try and take it down an inch or two. Then poured some self leveler to get my flat surface to put my hearth onto.
Other info that might be pertinent is that this is a 1908 house and I have no way of knowing whether this is original concrete or not. The area is 18 inches by 60 inches.
Otherwise, I understand I will need to use the self leveler anyway, and will want to make it as thin as possible so the hearth isn't raised up very high.
Do you think Bull Dogging it will be too much work? I would think the most work would be along the edge of the fireplace where I would need to probably use a grinder.
Any suggestions or tips would be much appreciated.
