Regasket glass door on older Vermont casting vigilant woodstove
Robin Warner
1
Hampden mass
My Vigilant Vermont castings woodstove needs new gasket around the glass. I hired someone to regasket the entire stove. I have done the doors and the top. But never window. I have had the stove for 40 years. Does the glass need to come out in order to correctly put new gaskets in. I assume yes. I think it’s a different size also. A bit nervous as the store told me the gasket set was a special order 100$ and I see them online for less then 35$. I am nervous.
You may be able to have it done at a local glass retailer. Chances are some screws that hold the frames or clips, whichever you have, wil break then need to be drilled and tapped. Can you post pic. s of the inside of the doors? I could tell you what you'll need...
I put new gaskets on my vigilant glass doors,I just applied some penetrating rust solution and left it for a couple days for the solution to penetrate,this worked well for me
Deno
If the screws break weld a small nut, the size of the screw or a size smaller to the stud, I have had better luck with wire feed than tig, it’s a quick heat shot to the screw, but the cast doesn’t really get that hot (relatively speaking) gives you something to get hold of and the expansion/contraction of the broken screw loosens the rust and it usually comes out by hand.
