My heat pump is pretty efficient when it's above 30 degree or so and I have been manually switching back and forth based on outside air temperatures. Decided it was time to make it automatic.
First I put two relays in my heat pump control circuit using the normally closed contacts for the compressor, fan, reversing valve ,aux and emergency heat. Heat pump runs normal in this configuration.
To control these relays I made up a control circuit that uses an inexpensive temperature controller marketed to control aquarium heaters, another ice cube relay a room thermostat a latching relay and a 24 volt transformer.
The controller is in Celsius so I have it set for . 3 C to go into heat mode and off at 1.5C. When the temperature drops below .3 the circuit closes sending voltage to the heat pump relay thru a relay which also has the stove thermostat circuit running thru it. So the heat pump relay contacts open and the stove contacts close and the thermostat for the stove to take over normal operation. If the stove fails for any reason the separate thermostat tells the latching relay to open the control circuit an the heat pump takes over.
It was a lot of fun figuring it out and so far seems to be working .
