Remote control switch for DHW recirculating pump
Rob711
455
Long Island, ny
I’ve purchased a hot water recirculating pump kit. It’s a circulator pump with a 24 hr timer and a valve that goes to furthest sink. Pumping hot water through the cold side.
I’m trying to find a remote controlled switch with a 5 min timer. I don’t want to use a app or ask Alexa. Ideally I’d have a remote/key fob I could leave next to sink. Hit the button, and turn on pump for 5 mins.
Seems simple. I cannot find what I need. Any ideas!!
EbS-P
4,856
SE North Carolina
Could you put a receptacle near the pump and wire the pump with a plug end and use a smart switch
gthomas785
983
Central MA
I just went through this myself. our kitchen is far away from where the water heater is. I ended up getting a smart plug and a smart motion sensing switch. Put the switch in the kitchen and programmed it to turn on the smart plug in the basement. Programmed the smart plug to turn itself off 5 mins after it turns on. Anytime someone goes into the kitchen it pumps hot water for 5 mins and you don't have to do anything or interact with it at all.
BTW, I started out with the crossover valve using the cold water as the return, but found the lukewarm water in the cold side to be unacceptable in the kitchen. In a bathroom it's probably not so bad, but I want cold water to drink at my kitchen sink! So for another $100 and a weekend's effort I bought a 100' coil of 1/2" PEX-B, check valve, pipe insulation and a few other fittings and was able to pull a dedicated return line most of the way to where my kitchen sink is. Now I have to wait ~10 sec for hot water instead of 4 minutes. YMMV.
Edit: BTW #2. Every smart motion switch I could find online has a "feature" that it will only turn on if it senses that the room is dark. Seems practical for lighting application, but is not useful for controlling DHW recirculation. I was able to open this one up by removing 7 small phillips screws, and simply clipped one of the legs on the photocell. Now it turns on any time of the day.
Rob711
455
Long Island, ny
Thanks for the suggestions, I found a switch with a 30 min countdown timer with remote. Now to see if it will work from 2nd floor bath to basement. Idk. I’ll let you know
