Hello all, first time poster here! I have been wandering around the forums for a while now and have found most of the answers I had been looking for and have been impressed with the informative and helpful nature of this site. I just had a few questions that I wanted to clarify. We just bought an older home with a Fisher Grandma Bear III woodstove. It was factory set up with a barometric damper out the back of the stove and a manual damper was installed in the chimney approximately 8” above the woodstove. My understanding is that the barometric damper should be sealed off if the stove is used only for wood. My question is, what is the best way to seal off the barometric damper. The barometric damper is sheet steel spot welded to the steel of the stove in two places. Can I use a similar sheet steel and high temp silicone to just cap the outside of the damper or would it be better to grind off the welds, remove the barometric damper completely and weld a quarter inch plate over the opening in the stove? Does anything need to be done with the inner “air box” associated the barometric damper? My other question is about installing a baffle. Since this stove has the inner “air box” for the barometric damper, can I still install a baffle? I read somewhere here that a baffle should not be used in stoves with this box. I appreciate any help you can provide.
