Hi All,
After a couple of months of deliberation with my wife, we've decided to convert our fireplace from a propane gas fireplace back to a wood burning fireplace (just didn't like the gas fireplace log sets and the fireplace insert is too expensive, right now). Currently, I have a capped propane gas line in my fireplace which runs out the back of the fireplace (back of the fireplace is visible and accessible in the garage), up the back of the fireplace stack, across the ceiling of the garage, down the inside wall of the other side of the garage and finally out of the garage and into the ground (and subsequently over to my propane tank on the other side of the house). There is a shut-off valve visible and accessible on the outside of the garage. Here is my chronology of events:
1) Turn off gas by the red shut off valve
2) Cut gas line on the top of the back of the fireplace (before it turns and goes over the ceiling)
3) Remove portion of line that's been cut by pulling through fireplace hole into house
4) Seal end with a brass flare cap
5) Mortar hole in fireplace
Any other suggestions or advice?
Thanks,
Tim
Thanks,
Tim
