Hello
It seems that because the blades are not in a sealed plenum like other stoves these blowers last longer. However changing them is not as easy as removing a few nuts or screws like other stoves.
I manually brushed the set screw with a small wire brush and sprayed PB blaster on it and left it overnight.
Saw this post
https://www.hearth.com/talk/threads...wer-fan-blade-cleaning-or-removal-tips.66633/
Have not tried a torch yet.
The allen wrench still will not budge. When this happened on other stoves, I just cut the shaft off.
However in this case, the set screw must come out to get the blower out.
Because of that, I cannot get a hacksaw on the shaft. Is there any way to get a tool in there behind the blades to just cut the shaft off?
See pics below.
Luckily it is not noisy like this one!
Saw this post
See pics below.
