So my lady and I purchased our first home and we're already looking at upgrading stuff.
Details:
Built: 1810 timberframe
1710 sq ft 2 stories
9 acres of wooded land, plus parents have a lot of land with trees that could be replaced
37 year old forced air oil furnace in basement with nice looking metal ducting throughout house
full 2 story height brick chimney with new stainless insert
fireplace in the living room with a blower that goes to the basement
secondary brick chimney with new stainless insert on opposite side of house
full height wet basement with narrow staircase in the living room to get down
New metal roof, siding and insulation within last 5 years
Lots of insulation in the attic.
electric water heater
So obviously the oil furnace needs to be replaced. The question is, with what.
First option? Yukon
I've been looking at the yukon eagle husky oil and wood furnace for a couple reasons. It's been around for 37 years and has been fairly reliable for people. It lights the wood using the oil burner. It can use the existing metal ducting. It can also be used out the same chimney. It can be dissassembled to fit into the basement downstairs. It has a water heater add on and can control an a/c unit.
Downfalls, it's a 37 year old design and isn't as efficient as a water boiler furnace from say econoburn.
It's about $5,500 shipped to my door, more expensive than just getting an "efficient" oil furnace.
I'm not sure if it's more or less money to purchase an entire indoor water boiler furnace though. I'm guessing less.
Second option? Kuuma
Only problem with the kuuma is that i want a secondary heating source and the kuuma requires its own chimney. If I got an oil furnace that would need its own chimney. The fireplace in the living room has its own chimney but that only goes to the 1st floor.
third option? water boiler
i don't know much about the cost of these. I'd want an indoor one like the econoburn i guess? But once again, i wouldn't be able to use an oil furnace as a backup. I'd have to use electric, and that's super expensive.
So what do you guys think? What's the most cost efficient way of heating a home using wood/oil/electric. (gas isn't available)
Details:
First option? Yukon
