Greetings.  I have a fireplace with a "coal effect" gas fired set which uses a SIT 820 valve.  Noticed flame not in the burner tray.  Shut it all down and after careful investigation, discovered the secondary flame is forming about a minute after the unit warms up, on the back edge of the valve between the top brass plate (Held on with a number of screws) and the valve body.  I guess the plate is warping under heat (as it consistently takes about a minute once the unit cools back to room temp, but if re-ignited after being shut down, the secondary flame appears immediately.   Seems likely the gasket material between the brass cover plate and the valve body has failed.  Was planning to take the plate off, and determine whether it is a "formed" gasket or a "caulk" type gasket.
Has anyone else attempted to perform maintenance on a SIT 820 who might have some tips/clues?
thanks!
tmy23
thanks!
tmy23
