Replacement of stove/stovepipe
AK2NM
2
New Mexico
Hello All-
I just purchased a poorly insulated 2000 sqft home here in New Mexico. It came with a woodstove, however it is past the end of its life (Firebox is cracked). I am considering doing a new self install and would appreciate some feedback. My current thought is to install a Drolet 3000 and line the current 8" single wall stovepipe with a 6" flexible stainless liner. Does this make sense?
A couple other things:
  • We're at 5800'
  • Stove would be supplementary heat
  • I'm pretty mechanically inclined
  • Current stovepipe is ~10' from top of stove to discharge above roof
Stove as it is now:
[Hearth.com] Replacement of stove/stovepipe
I would replace the pipe and it line it. I am not sure code supports lining that type of pipe.
Just run 6" stovepipe to a 6" x 8" increaser at the ceiling support box. It probably will be necessary to add another length of chimney pipe for the Drolet for it to draft properly. 10' is too short for modern stoves at sea level. Fortunately, the Drolet breathes pretty easily. At a mile up I would add 4' to the chimney.
Do you know what brand chimney has been installed? Make sure the chimney pipe can be identified and matched. Brands can not be mixed. If this is a 25+ yr old chimney installation, it too may need replacement.
Thanks for the advice here. The stove was manufactured in 1982, so I'm assuming that the stove pipe was installed then too. Sounds like I should just replace the whole thing, stovepipe and all. I appreciate the advice.
Yes, if it's 1982 chimney pipe, the odds of finding another length are slim.
