Replacing Throttle Cable on Stihl 011 AVT
tomminny
3
Central NY
Hi,
My Throttle Cable broke on my Stihl 011 AVT. I have pulled the handle apart and opened up the top to the Carb. area-under the air filter. I can see where the old cable goes (half of it is still there and attached to the throttle plate connector). I also pulled the boot that covers the carb adjustment screws. Is there a trick to getting the new one in there or do I have to take the saw all apart to replace it?
Thanks in advance!
Tom
tomminny said:
Hi,
Thanks in advance!
Tom
is the 011 avt a chainsaw or weed eater?
tomminny said:
Sorry about that... It is a Chainsaw
here the manual (broken link removed to http://www.stihlusa.com/stihl_ownersmanuals/STIHL010_011_with_safety_manual.pdf)
Thank you so much for the manual.... I cannot find anything in it about replacing the throttle cable though.... Do you happen to have a service manual for it?
Thanks again!
Tom
Thanks again!
Tom
thats the only manual, i also look at racesaw.com nothing on cables or 011 sthil,all the newer sthils dont have that kind of set up
I haven't done a throttle cable on that saw, and I've only worked on a couple 011's, but my gut is saying a lot is going to have to come apart on the saw. How old is that saw??
Ok, I just took a look at a couple pictures. I'm thinking at least the handle and air filter cover. Not sure what else. How's the saw run? She's an older one for sure!
Did you ever find a response to your problem? I have the same saw and ordered a new cable from my local Stihl dealer and found that it is too long. Reconfirmed that correct part number was ordered as per the parts manual. So now I have posted the issue to ArboristSite.com.
I am really looking for the correct part number to order so I can get this fixed. Part number I ordered that is too long is 1120-180-1100.
Thanx,
Dan
