Hello all,
I discovered this forum while doing research on wood stoves and have been reading the forums ever since. The site has been a great source of information. Thank you!
At this point I have done so much reading that I am swimming in the choices that are out there. I am requesting your expertise to help me break it down to a couple options that would work best for my setup. I am currently building a home in North Carolina in a rural area northwest of Charlotte. Our winters are mild, with temperatures rarely below 20 degrees at night. Most of the time we see low temperatures in the thirties and highs during the day in the forties and fifties. The home is a well insulated brick veneer with roughly 1350 sq ft on the main level, and about 1000 sq ft finished in the walkout basement. The main level is a very open floor plan with 9 ft ceilings. The staircase to the basement is open and is located on the opposite side of the living room from where the wood stove would be. My plan was to use the HVAC fan to circulate the heat around the main level and down into the basement, and supplement downstairs if needed with a heat pump.
I would like to have an efficient stove that can get through the night. I also don't want it to burn us out of the main level. I hope I have given enough information, but if I haven't please ask. Thank you in advance for your help.
