Hello all, I recently designed and built my very first house. It is a ranch style home utilizing a closed loop geo-thermal heat pump system. The house is a walk-out style house and I purchased an Alderlea T6 which I built a slate hearth on the lower level. The house is 2,000 sqft upstairs and 2,000 sqft downstairs. Installed the main return trunk so it ended directly above the unit on the lower level. The duct sits about 10 feet above the stove itself. I have temperature sensors located in the return duct to sense when I have the wood burner on. If the return duct senses any return air temperature above 90 degrees a controller disengages the variable speed compressors on the heat pump and turns on the main supply fan. I oversized my stairwell width and have it at 5 foot wide. I manually will close the return air ducts upstairs and force the cooler air to funnel down the stairwell. It works well for the most part. Now my problem.
I burn seasoned Osage Orange (Hedge Apple Trees) only. Our farm is littered with them. My stove will heat up easily enough but will burn through a full load of hedge in a matter or hours, approximately 2 hours until I would have to go down and reload it. I am seeing temperatures on the top of the stove around 600-700, the return air duct temperature sensor says that the air temperature is approximately 105-110 degrees F. I can't go any higher than that because my heat pump refrigerant coil is in the same air stream and I run the risk of boiling my refrigerant if I go any higher. My flue temperature is hovering right around 700 degrees. I believe this stove has a EBT (extended burn time) unit built into it for allowing overnight burns. I have yet to even come close to get a 5 hour burn off a full load. I do have what I believe to be the optimal burn setting marked on the damper. This where I can re-stoke the fire and the stove will stay at a surface temperature of 700 degrees and my flue temperature will not increase either. My questions are:
- How hot should I be running this stove, what should I see for a surface temperature?
- Has anyone ever gotten this ETB device to work?
- How hot before over-fire happens on this stove?
- Would a fan help move the heat? If so where should it face? (Remember the return duct is located directly above the unit, so I don't think a fan will do anything special?
- When I do get the upstairs heated from circulating the air from downstairs up the lower level is really uncomfortable.....Does this really need to be this way or can I move air better?
