Rutland vs OEM gasket Adhesive
cabinwarmer
250
SE PA
Good Day, I had this posted on a similar thread, but thought it may be better to start a new one to share.
Which one would you recommend I use? The Imperial brand was included in the OEM gasket kit. This is for the 1/2 door gasket.
Dave
[Hearth.com] Rutland vs OEM gasket Adhesive
Any opinions? Looks like from the past forum posts, RTV tube might be best. Going to start this project now, any feedback welcome.
Dave
Rutland,for sure
excellent, thanks
Rutland shows 24 hours to 100% cure. How long before I can light the stove?
I have started the stove after an overnight drying, probably around 12 hrs, using RTV without ill effect.
Thank you Sir.
I have done gaskets with a hot coal bed in the stove to the point I had to use gloves when handling the door. High temp silicone worked fine
