I have a Qudra Fire Santa Fe that the auger wont run. I have check the vacuum hose and cleaned hose and port on the auger. I have applied vacuum to the vacuum switch with a hand held vacuum pump and auger still wouldnt run. I bypassed the vacuum switch and the auger runs and stove works. Should the vacuum switch hold vacuum? With the testing I have done I am thinking the vacuum switch is bad am I on the right path? TIA
