Hello, hope this is not a dumb question but here goes. This morning I had the smoke alarm going off real well. What I did was like I do in the morning I check to see if I had any hot coals and today I did. Added some small splits then some bigger stuff all real nice and dry. I had the air open all the way and the door cracked about 1/2" open. Once the fire started going good and the probe thermometer was showing 400 I closed the door. I then went to read all the new posts on the site here. Did not even think about not having closed the air down. Well after about 10 minutes the alarm was going off. The stove top was only at 400deg but the probe thermometer was at 1000 and the mag mount was running at 550. I did have a hot smell coming off the flue pipe or stove. I shut the air off and turned the blower on the stove to on. It cooled right down in no time. Was the smell just because I have never had it up that high? I have been try to keep the stove top at 550, probe to around 900 and the mag mount at 400. When I first installed the stove I did paint the flue pipe and the stove so it would all match. I used high temp stove paint. After all the burning that the stove has seen I was surprised I'm still getting a smell or some kind of burn off. I did use high temp silicone were the chimney comes threw the support box for a good seal, so could that be some of the smell?
Do I need to check something? I have been checking the chimney weekly and only been getting gunk in the very top of the chimney and in all of the flue pipe. Very hard stuff in the flue pipe but not shiny like glaze. A brush does not touch it has to be scraped off with a screw driver.
PS. Sure had one great looking secondary burn going on!
Don
Don
I would check the silicone at that seal you mentioned, though it's probably OK. I'd give the rest of your setup a quick once over as well, I doubt you'll find anything wrong, but it never hurts to check.
