While reading another thread about secondary burn and the high temperatures needed, when you damper the stove at night, how efficient is your burn? Also are you letting a lot of volatile gases escape without being converted to heat?
oak194 said:ok well let me ask this then, yesterday i brought my quad 7100 up to temp, and after the house was as warm as I could take, i closed the draft down, and within an hour my front glass blackened to the point you could not see thru it. Which as far as i can figure was from the fire just smoldering. correct?
Am i doing something wrong? this is my first epa wood burner, i'm used the the old simple, no burn tube type.
Jags said:oak194 said:ok well let me ask this then, yesterday i brought my quad 7100 up to temp, and after the house was as warm as I could take, i closed the draft down, and within an hour my front glass blackened to the point you could not see thru it. Which as far as i can figure was from the fire just smoldering. correct?
A whole bunch of that depends on the draft that your system produces. It IS possible to have a system that when the stove is turned to its lowest setting, will "snuff" out the fire. Meaning that it does not let in enough air to continue combustion. It happens. Doesn't really mean that you are doing anything wrong, its just a characteristic of YOUR setup.
Some people drop their air control to its lowest setting. If I do that, I will have charcoal chunks the size of your fist that are unburnt. I have to stay 5-10% open to get a complete burn.
Concerning the draft, Isn't it true that the draft will be significantly weaker this time of year vs in the dead of winter when temps are a lot colder?
BurningIsLove said:Even when you damper down the primary air control all the way on a modern, EPA-approved stove, there is a secondary air supply that keeps the secondary combustion going which efficiently burns all the gases & smoke. The EPA regs. require this so you cant damper down so much that the stove smolders & burns uncleanly.
Its great because your firebox fuel lasts a long time w/o reloading, and the secondary combustion of the waste gases/smoke keeps the temp hot enough to sustain itself.
Let me clarify my question, first my wood was split and stacked two years ago, tested with moisture meter, and the wood is dry. I have a straight chimney, double stainless inside, class A outside. What I am referring to is as you damper the stove down, the inside of the box drops, to light off the secondary combustion you need a minimum amount of heat. Even though you cannot close the secondary combustion air, the stove is not hot enough for secondary combustion. My feeling is it then lets combustible smoke and gases up the chimney.
When I start a rip roaring fire with lots of dry kindling, there is no secondary combustion, until the entire stove gets hot, and it occurs best when I damper down about half way, after the fire is nice and hot.
Just a thought I would kick around with my fellow pyros.
