Secondary eye candy
begreen
Mooderator
Staff member
111,675
South Puget Sound, WA
I had a nice thick split of wild cherry on top of the doug fire splits in a reload last night. Once the fire got burning we were rewarded with a very nice secondary display. This lasted almost two hours. It was better than what was on TV.
Folks have asked about the PE secondary burn so hopefully this will illustrate what it looks like when the stars are aligned and the wood is right.
Up here in New England we have hard wood and if you even mention burning soft wood “you’ll burn your house down with cree -o-soot”. People just don’t get it, but the white pine we have here has a lot of pitch in it.
Where I’m trying to go with this is, to get that nice secondary burn with hardwoods it NEEDS to be well seasoned wood, or you’re going to have a hard time. For example I was burning some oak that’s been seasoning (css) since Nov, 2021. It didn’t burn well and not easy to get secondaries but a different species of oak of the same age worked great the past 2 years. Oak can be tough to work with.
I agree.
I'm burning oak now that's either 4 or 5 years old. I tested a few splits earlier and it's between 14 and 16%.
It's very easy to get nice blue orange flames at the top (even without secondary air...)
The annoying thing is that it takes off before I'm done reloading, making for interesting testing of my gloves and sleeves. Especially when trying to pack the most in the box.
We're normally burning Doug fir. Our hardwood stash is from various yard projects and is seasoned for 3+ yrs. I gave my splitter to a friend in need last year, so there won't be a lot of hardwood in our stove once this stash is gone unless I buy it.
When you achieve secondary burn like this, is your air control lever all the way closed down? If so, do you ever have to let a little air in after a while to prevent it from going out or getting a back puff type flame that comes on with lack of oxygen?
I usually run with the air slid to off. It’s outside temp and wood dependent as the stove needs to be drafting well.
Reactions: SkidKid
Yes, the primary air control was all the way closed. However, the air control never closes off completely. That is by design so that the fire can't smolder. There also is unrestricted seconday air still being fed through the baffle.
Note, that I mainly get this kind of display when burning hardwood. I rarely see it burning doug fir.
What was your stt? And flue temperature in this video ?
When you say unrestricted secondary air still being fed through the baffle what do you mean? I thought on your stove model the primary air lever was connected to the secondary air? So if you turn down the primary you are turning down the secondary?
No, that is on the earlier mid-sized, T5 and Super. The early T6 and Summit have an unrestricted and unregulated secondary feed. They tried the EBT 1 for a couple of years but that regulated the boost air and was not successful. The EBT 2 replaced the EBT1 around 2011 or 2012. That is when the big PE stoves got a regulated secondary. The EBT2 was not added to the T5 and Super until around 2018 or 2019.
Reactions: Tech Guru
Would your secondary feed be basically where my EBT2 is? Underneath your stove, do you have another hole right next to the boost hole? So like mine I have the primary lever hole, boost air hole and another identical hole next to it.
Yes, except that the secondary tube is open at the bottom on our stove.
The air control changed from the older models but has the same function except that it closes off further. That's why that second air hole. The older model's does not close all the way off and therefore doesn't have the extra hole.
Ohhhh ok gotcha. Thanks for clarifying for me.
Now that that is clear I wanted to remark that Begreens standards for secondary enjoyment are very low ;-)
Better than TV is a low bar 🤣
Do you have a video of what it looks like after secondaries are done? Does it just become a coaling stage and no flame?
no
It does become a coaling stage. Different woods have different amounts of coaling.
