Which boilers out there would you recommend? Why? Are there boilers to stay away from? What should I know about draft inducers verses natural daft. Is it just a matter of chimney length? Some manufacturers claim their parts are easy to get. Are some models hard to find parts for? Is there a clear choice of the best boiler for the money? I appreciate your opinions. Thanks.
Please read on, only if you want some background information!!
The situation
I live in eastern Ontario, just north of the US border. I built my house about 10 years old and well insulated. There are many large windows but they are as energy efficient as possible. The house is fairly large at just under 3000 sq. ft. including a finished basement with walkout.
I currently heat with a high efficiency fireplace on the main floor and in floor radiant heat via a propane boiler in the basement. I installed this myself and it works quite well with a 3-way mixing valve connected to an outdoor reset controlling the water temperature going into the floor.
I burn 3-4 cords of hardwood (mostly ash) each season and 1600L (425 US Gal) of propane. I buy my firewood in logs and cut and split it myself. My hope is that I can install a wood boiler that can take over from the propane boiler and also reduce the amount of wood that is going through my fireplace (which burns 20 hours per day).
I have an attached garage that I would like to heat slightly. There is an attached shed on the back of the garage that holds my firewood. There is enough room in there to place the boiler as well. Its about 10 x 30. The boiler would be on the other side of the basement wall from the propane boiler.
I have a hot tub I would like to heat. We use very little DHW
What I've learned so far...
From the posts I have read here I am estimating that a gasification boiler would consume about 5 cords of wood in a typical season. I also am convinced that thermal storage is very desirable. I've also learned that there is a very wide selection of boilers to chose from.
Selecting a Boiler
Many years ago I was considering a Greenwood Boiler. Sounds like it was a good thing I couldn't afford it then!
I have looked at the Empyre boiler. It looks good but I hear several people talking about leaks. I went to a dealer to see one. The only one he had to show me was a leaker he had recently replaced. Also, the Empyre is not pressurized and I would have to run a heat exchanger to tie into my existing boiler.
The Econoburn is very interesting due to it heavy construction (1/4 inch plate) and 25 year warranty, but a bit pricey.
I see many people post that they are using Vedolux boilers. I like the thought that went into designing an easy way to clean the heat exchangers. It is priced better than some and it seems to have a 1/4 plate steel firebox too. I have been looking at a Vedolux 37 that comes with a re-purposed 500 gal propane tank for the same price a an Econoburn (without storage).
I looked at the Garn JR. Interesting but too expensive.
I considered a pellet boiler but firewood is much cheaper than pellets and I hear people saying that they are becoming hard to get in some areas, which will make them even more expensive.
The situation
Selecting a Boiler
Read what I wrote flying cow. Said one of the coldest parts of the northeast. -5 this morning at my house. We had a couple of days of -29 this season, and too many days way too far below zero. And we are, Ogdensburg and Massena, NY, one of the coldest parts of the Northeast on a regular basis. And I always keep an eye on anyone from Maine with unpressurized storage. Blaaaaaaaa.
