Selkirk Pipe Is Junk
Brokenwing
448
Northern Maryland
Im so aggrevated right now. Been waiting for months to get this stove running. chimmney company showed up to do the inspection, looked at everything and said it looked great. Fired up the stove and the house smelled like we had a campfire in the living room. Embers rolling out of the 90 degree fitting where the joints are pressed at the factory, and the from the bottom of the tee, and the hearth was covered in ashes. They put some more sealent on the 90 and took the tee cap off the bottom. I was in disbelief them suckers did not even put a seal around the tee cap. They put so much sealent on it, and it seemed no more embers were blowing out. They set the draft and packed up and left. Low and behold embers are coming ouf of the tee again. My mother who has bronchitis is so closed up I thought i was going to have to take here to the hospital. He said the only pipe they use is simpson duravent, and he showed me why. Selkirk pipe is rolled and pressed at the seams, where as simpson is all welded at the factory. The simpson tee also has a neoprene gasket which selkirk does not. I might pull this pipe out, this is ridiculous. 3000.00 dollar investment and can not use it. Man im beyond pissed. Like the dealer told me simpson use to be nothing but problems, but the stuff is wonderful now, meanwhile Selkirk is still press fitting the seams not welding it.. Sorry for the rant just very frusturated right now.
Reactions: Lousyweather
I have no expierence with VP pipe, but the DT is good chit.
Also DT inner pipe is spot welded and sealed with cement.
I was not impressed with the VP pipe, adapters, tee, either. I had to use some pieces to convert to the Direct Temp pipe. If I had to do over I'd just go with ICC..
Ruh roh!!!
Sorry you are going through this, Brokenwing. You might just want to take your time now that the season is almost over and replace the pipe for one you feel safe using. I am biased for ICC but that is because it works well for me.
But I think you said you could not get it close to you.
Icc I called everywhere looking at it. I moved home cause Im dissabled, and my dad has some medical conditions as well. I thought putting the stove in would help him as well since he is really cold. This did a number on my mother though she is so sick tonight. Only Thing I can think of is run it again with a Co detector and make sure its not leaking anymore. I contacted Selkirk and spoke to the enginerring department and they want pictures. Im going to work with them on solving the problems. I know I had a heck of a headache but i figured that was from the inital leak and the stove pipe paint curing. As far as everyones pellet stoves here, do you get any smoke smell inside your home at all, since it is a woodburning applicance?
No smell... The stove and pipe (if painted black) will smell for up to a couple days. It may even be strong enough to set of smoke alarms.
My dealer did a good pre-burn on the stove. No smell ever. My Woodstove stunk for over a week though. Every time you hit a new high temp (higher heat level) you may smell it again. Weeks down the road.
Be patient and listen to what there dept tells you. Hopefully they get it all worked out.
If it makes you feel better. Simpson Pellet Vent Pro isn't perfect and has a lot of Haters on here. I like it and only had to seal the 4" system on my Pellet furnace. My Shop stove and Quad upstairs have 3" and only have high temp on the appliance adapter.
My stove was a display model so that has no smell. I have a feeling its the stove pipe paint curing from the factory. They just need to fix this tee for me. I hope to god I dont have to take the stove out if it is going to make mom sick. Im hoping the smell will go away.
Ive bought 3 sets of Selkirk venting,One 21 feet up...they all smelled hot(fumes)for a bit....my 2 cents.....
  • Selkirk Pipe Is Junk
I'm having issues with 4" duravent right now if that makes you feel better. No health issues in the house just the ole lady complaining about the smoke smell. And no embers escaping. That kinda sucks.
Well I know yesterday I was mad, but Im speaking with a great rep at selkirk and she is working with me to try and solve this problem Im sending some pictures over to her, so engineering can see what they can do about this problem. It does make me feel a little better knowing they are willing to work with me.
I don`t have any problem with my Selkirk pipe. 4 yrs and never a trace of a problem regardless of how the seams were done.
It beats me how embers can escape a double walled elbow. Heck, I`ve never even see embers come out of a single walled wood stove elbow.
Are you sure the elbow wasn`t defective or damaged initially?
I was amazed myself, but embers were coming out. I understand how they can come out of the tee with no gasket but the elbow had me scratching my head. I wish i had a video camera I would of shot a video so you all could have seen it. I spent two hours last night going through threads on here to see if anyone else had a problem like me. I found 3 threads where members had leaks as well as embers escaping in the same area. So I sent all those thread to engineering so Selkirk could see that im not the only one with a problem.
Well just a update I have been in contact with Selkirk, and there trying to help. I got a email from them telling me that my pictures look like my tee cap is in wrong. I explained to her it was in proper, the chimmney company even looked at and said it was in proper. I even showed her links here where folks here have had the same problem as me. I ran it in the dark and checked with a flashlight to see if I can see smoke and I see nothing now. The problem is its giving me a headache, and If you smell where the air comes out from the blower there is no smell on the right side, but a smoke smell on the left. I think there is a leak still some where and the blower is picking it up and blowing it out the front. Im about ready to pull my hair out, we have a frost warning tonight and I would love to be using it.
Maybe try looking inside the stove.....
A few M-55 owners had problems like this at the beginning of this season. It ended up Not being in the venting at all.
It was the the exhaust collar of the stove (where the stove adapter/1st piece of vent) where it connects to the actual blower housing. IIRC, someone had to even double up on the gasket that goes in there. The way its secured seemed pretty shoddy.
But this area is near where the convection blower can pick it up (within the stoves shell).
Brokenwing, did you ever post pictures somewhere else of the exhaust pipe setup? specifically the tee? the tee cap?
And Dexter is correct about the M55 exhaust starter tube connection can lack tightness on one side of the connection. You can kind of visually check it by looking at the white gasket in between the exhaust starter tube and the motor housing. There is one screw on the upper right corner and two metal tabs folded over the other side of the starter tube. The gasket material on the metal tab end will look thick, thicker than the material on the other end where the screw is. If the exhaust pipe is disconnected, you can also pull on the starter tube and see if it wiggles a little on the metal tab end.
Here's the link to my ordeal: https://www.hearth.com/talk/threads/finally-fixing-the-m55-installation-and-some-questions.75676/
Selkirk Pipe Is JunkSelkirk Pipe Is JunkSelkirk Pipe Is JunkSelkirk Pipe Is JunkSelkirk Pipe Is JunkSelkirk Pipe Is Junk
However, it is very hard to check more carefully without disconnecting that starter tube and moving the stove if it is in a tight place. Not something anyone can do because of the difficulty moving the stove and the technical knowledge required.
I also think if it does leak, it leaks very little, almost unnoticeable. For the amount you are smelling it sound like the tee or some other part of the pipe is leaking.
I can post some pictures vinny. I bleieve this is where the problem might be. Im going to put some more silicone around the flange of the combustion blower. I will post some pics of the setup for you. I think I have the pipe sealed, Im not seeing any smoke or embers from the pipe anymore. Anyway here is some pics of the setup. Thanks Vinny, Dexter, and everyone else that has replied thus far, Im so stressed and all help is appreciated.
From here it looks okay. I don't see silicone in the space between the inner and outer pipe of the stove adapter. That could be the culprit. If there is a leak anywhere in the pipe, smoke will find its way out that space. If you are going to take it off, it is best to put a thick bead of silicone there.
As for embers, it is hard to imagine burning pellets making it to the tee. Maybe you saw the burning ash.
Let us know how it goes.
Ya its hard to believe but before we siliconed it up you could see embers coming out of the tee. I have the ember problem taken care of now im just chasing a smoke smell. Im not planning on taking the pipe off I have so much sealent on that thing its not even funny. I took the stove panel off on the left side of the stove near the combustion blower per your post. I found some areas of silicone that look like it could of been missing. I siliconed the heck out of that, and If it cools down one evening I will fire it off and see If i have the problem solved. Im still working with Selkirk I think there going to send me some new parts. I thought this would be easy, buy the stove, install it, and done. boy was I wrong lol.
Hate to say it, but you will have to disconnect the stove from the exhaust pipe for maintenance at some point. Removing all that silicone will not be easy or fun. Make sure you get it to work without all the extra silicone, or at least device one connection point that is easy to take apart for future maintenance.
The exhaust starter tube and folded-metal tab connection is supposed to be that connection, and you should be able to disconnect that one bolt and slide it over to disconnect.
Good luck.
Yup. I would recommend sealing up that secondary space at the adaptor. Thats what I did and have no more smell.
Well the way I have it I can still unhook the stove pretty easily. You only need to change the gasket on the combustion blower bi anuanaly correct. I will seal around the secondary adapter space, and see what happens. Were suppose to have a drop in temps next week so we will test it out and report back.
If you need a ton of silicone to keep it from leaking I would demand a refund from Selkirk and go with the ICC. ICC is worth its price, I have never had any problem with mine no matter how many times it's taken apart. Go on their website and put in your zip code. There are dealers in mt aire MD, and York, PA.
