First off I want to thank everyone here that helped to get me this far! The Hotblast 1551E is installed in my unfinished (dirt floor/stone wall) basement. Chimney has been put up twice now after getting a bad ceiling support box and replacing it. The chimney is 34-35’ of actual height, through the house, of 6” Duraplus with one pair of 30 degree offsets in the attic. I added a flue damper directly to the back of the wood furnace with the Duravent DVL damper/stovepipe adapter piece. This put the damper in horizontal pipe instead of vertical like most I have seen but seems to be working ok. It is DVL from the furnace to the ceiling support box. No single wall at all was used. The auto draft doors damper control motor didn't work right out of the box. USSC sent a replacement and so far seems to be doing its job now by actually opening.
Onto the topic. I finally removed the two 8” 90’s and scabbed together ductwork I had to give me two temporary registers. I had a plenum made the size of the top of the Hotblast 32”x22”x15”H with 1” flanges. Currently one side has 15’ of 8”x 16” ductwork feeding three 6” takeoffs and one basement register I usually leave closed. The other side has just one 6” collar directly off the plenum to one 1st floor register about 7’ away. This was a definite improvement but now it seems like my factory blowers are really working to keep pressure in the new ductwork. I originally planned to run in series with my existing FO furnace so here we go!
My plan is to use the 8x18” ductwork I already have to go from the FO furnaces top exit hot side to Hotblast wood furnaces bottom rear cold side intake. So far I only have to buy a longway 90 and two shortway 90’s in 8x18”. The 8x18” will run horizontal 4’ from the fuel oil furnace into the longway 90, into a shortway 90, sending it down about 3.5’ to the second shortway 90, then about 4 ft horizontal to get into the back of the Hotblast. I plan to remove the HBs factory cold air filter box to reuse on the FO furnace cold side and remove the factory blowers and throw them in the corner. I want to make the HB and FO furnace both run the FO furnaces blower for heat distribution. Since the HB factory blower openings are so small for the blowers I am thinking I might have to cut out where they mount to the full 8x18” ductwork size feeding it to get rid of the bottleneck. I am also wondering if I might want to cut out the metal between the two 8” outputs on top of the furnace under the plenum as well?
Thoughts? Opinions? Did I already mess up besides getting the HB? Can anyone steer me in the right direction for wiring the HB to the FO furnace blower correctly? Specifically, laynes69 and brenndatomu, I am hoping for your input here! Haha, thanks again everyone and stay warm!
