Has anyone ever used these, have a tight spot where I am installing a new shower faucet (small access panel in a linen cabinet) and was wondering if these might work, not really wanting to use a torch in such a tight space!
They work great. Cut the pipe clean & sqaure on the end, clean off any burrs, and slip the fitting on. It is that easy.deck2 said:Has anyone ever used these, have a tight spot where I am installing a new shower faucet (small access panel in a linen cabinet) and was wondering if these might work, not really wanting to use a torch in such a tight space!
thinkxingu said:Sharkbites are super, but they have their limitations: 200 PSI max and code dictates they're not used behind walls or where they can't easily be seen (the same, I think, with compression fittings). I think we've not seen them as widespread because they might put plumbers out of business--sweating's the only hard part of plumbing and this prevents it!
S
thinkxingu said:Hog, no--the 200 PSI shouldn't matter since if you've got over 90 in the house (most incoming is between 60-90) you'll have problems with leaky valves anyway. I only mentioned it because that's one of the criticisms--regular sweating/pipes/valves are rated at 300 PSI. Let's also not forget that there will be momentary pressure spikes.
S
