There may be a problem with a silicone pellet vent pipe. Do I have to replace the pipe?
The chimney sweep came today to clean the chimney, the flue liner and the 3" Simpson pellet vent. He could not open the cleanout cap at the bottom of the T-pipe that connects the stove to the pipe in the wall. This is a problem. (The hardware is an UltraPro 3156 Ti-Alloy 3"x18" pipe with collar plate, tee and tee cover, appliance adapter, black 90 degree elbow, 36" pipe, 24" pipe, 12" adjustable pipe, wall thimble.)
The reason he couldn't take the cap off is that when the dealer installed the stove and attached it to the T-pipe that the chimney sweep put in, the dealer's guys then put silicon inside the edge of the cap and on the bottom of the cap. I'm supposed to be able to unscrew the cap by hand from the bottom to drop out any fly ash, maybe every couple of tons. But the only way now is to unscrew the T-pipe from the stove then also unscrew the pipe from the entry into the wall hole. That means disconnecting the stove entirely to get rid of two or three inches of ash. That's definitely not the way the stove and pipe are designed to be used.
The chimney guy I've known for years and he does a good job. The dealership is OK and obviously the guys connecting the stove to the pipe had the best intentions. They put silicone all around any possible crevice from stove to plate in the wall which I guess was good although I think these pipes and stove are designed to just snap in. I had no problem all winter and the stove worked great.
The dealer is scheduled to clean the stove in a couple of weeks. I think the dealer caused the problem by putting the silicone on and preventing anyone from just using the cap by pulling it off manually. So he should fix the problem. I'll see him before they come to the house and explain the situation.
But I want to be reasonable and be sure I am understanding the problem correctly. Any suggestions?
