Sizing a PE Alderlea for new home Construction
Aonghus
2
Virginia
Greetings and thank you to everyone on the forum. I have been reading and referencing information on here for a couple of years (which has been extremely beneficial) and am now planning to build a new home. As such, I was hoping to tap into the wealth of experience present on the forum and get some feedback from those willing to share.
I live in Southwest Virginia, USDA zone 6b/7a. Winters are generally mild here with the coldest period averaging highs in the upper 40s, and lows in the 20s. Cold snaps can leave us below freezing for multiple days at a time, but are not very common.
I'm in the process of beginning a new home construction. While I can't give specific specific insulation values, I can provide basic construction information.
- 2400 sq/ft living area
- 6" wall construction
- Metal roof and siding
- Single story, crawl-space
- 9' ceilings
- open living area, with most rooms directly connected to central large area
- Multiple mini-splits instead of a central HVAC/ductwork
I am attaching the basic drawings for reference
I'm very interested in the PE Alderlea line of stoves due to good feedback, both on the forum and from a chimney sweep i know, and my wanting to avoid a catalyst. My experience with woodstoves is limited. I am coming up on my 3rd year of using a buck 74 that was installed in the fireplace of our current home.
For the new home, I want to optimize the stove installation and not have the constraints from a fireplace and liner.
My main questions:
1. Sizing. Have I provided enough information for you folks to recommend a size (T5/T6)?
2. Draft. I plan to have a straight vertical run through the ceiling and roof. What lengths work well for these stoves, and at what height should I start considering a damper?
3. Can these stoves' air intake be accessed/occluded in the case of overfiring?
4. How well do these stoves burn with partial loads?
My wife and I both love heating with wood (she grew up doing it) and would like to have the wood stove serve as our primary source of heat during the winter. I'm a big fan of using kerosene heaters for backup and supplemental heat during cold snaps, and keep moderate stores of kerosene at all times. As such, I'm not opposed to using kerosene for supplemental if you thought a larger stove would be sub-optimal for general use and only needed during the coldest periods of weather.
Any and all feedback is very much appreciated, and I will do my best to provide any other relevant information.
The T5 should suffice with this well insulated home. Plan on an outside air feed from the crawlspace.
The main control against overfiring is stove operator. We have been running the T6 for many years and there have only be 2 overfires where I had to open the stove door to slow it down. One was due to a spaceout with small wood starting pieces and the other was when I replaced the door gasket with Meeco Gold gasket material. Lessons learned: a digital alarm helps prevent spacious (so does a timer in your pocket) and only use the OEM replacement gasket.
These stoves are easy to run. They will burn fine with a partial load of fuel. Burn thicker splits for a longer burn time and less drama. And pack the splits in tightly to minimize air gaps. Don't build lincoln log style fires with the splits criss-crossed. A digital probe thermometer about 20" up the double-wall stove pipe gives the best guidance for air control. If desired, a key damper in the stovepipe can be put in for further control. We have one, but it is rarely used. Due to our milder climate, draft is reasonable until it gets in the low 20s outside.
@begreen
Thank you for the reply! I'm assuming you're talking about an Outside Air Kit (OAK)? Do you recommend OAKs in general, or is this based on building code?
I'm planning on a sealed crawlspace and I would anticipate around 30' of air duct to get the outside wall. Maybe 18' if I could run it to the garage. I haven't done any research on OAKs to know if this is an issue.
Also, do you think I should install a damper or try it without first?
Based on your recommendations on the forum, I installed an Auber thermometer on my current stove (contact probe sandwiched between the external wall of the liner and it's insulation) and can't imagine running a stove without it.
Thanks again!
OAKs are a good idea for tightly sealed homes. It helps supply the stove with combustion air when competing fans (dryer, bath, and kitchen) are exhausting air out of the house. If the crawlspace is a sealed, conditioned space, then plan on ducting fresh air from the a perimeter wall. The duct size will depend on the lenght of the run but it should be at least 4".
If you are on the milder DC side of the Appalachians, then a key damper may not be needed. It doesn't hurt to try it for a season without one.
