Small fires, am I just asking for Creosote?
Dajolu
156
Long Island, NY
I use my wood stove basically as "Natures TV". The heat I get off it is a bonus. Friday, Saturday, Sunday night after the kids are in bed. I'm not really comfortable leaving a loaded stove all night while we sleep. I have been only putting about three average size oak splits in with a decent amount of kindling on top to get it all going. I run it hot for a bit to get the cat active and then shut the air down. Then when its time for bed I am not worried about the stove running away or anything like that will a packed stove. Is having these smaller sized fires asking for creosote build up? Or as long as I keep things hot I guess I'm ok?
Reactions: Burnin Since 1991
Keeping things hot you will be fine, with cold starts you always have a higher chance of buildup due to the initial hurdle to get your flue up to temperature. I work extreme hours so I end up cold starting alot. The trick seems to be using a lot of really nice kindling to get heat up the flue right away.
What I would do if I were worried is I would do one of your typical burn cycles during daylight and look at the chimney through the course of it. If you see smoke coming out, then you’ve got some likelihood of creosote, though even a bit of smoke might be nothing to freak out about.
With my non-cat stove, I’ve gotten pretty good at running it, but still sometimes I go outside to do something and smell smoke I wasn’t expecting, and I see it coming from the chimney. I go in and give it more air. Even with these episodes, sweeps have never found anything more than a bit of soot in my chimney.
As long as your wood is dry and your burning hot it shouldn't be bad. Did you do the same last season? How did the flue look at the end of the season?
Flue wasn't bad but didn't look ideal for only burning 1/3 cord TBH. But my wood was marginal and now I am burning verified dry stuff. I think I have to just make sure I am getting the flue hot enough. I don't have a temp gauge in the pipe but I supposed I should invest in one.
Reactions: kborndale
Can you approximate in hours old is your cat?
Ah, good question. Last year was the first full season I used the stove. Not many hours on the Cat.
Ok I was looking to see if that had to do with your flue not looking ideal but wouldn’t think that to be the cause then.
This will make all the difference. Using only seasoned wood is the #1 way to prevent creosote. You should be splitting kindling right now for the next seasons so that your kindling wood is extremely dry and easy to start. You want the kindling to put off as little creosote as possible (when things aren't yet hot) but at their most efficient to create that hot fire.
