I am looking for recommendations for smallish stoves that are good for cooking and can also sustain a burn overnight.
I am looking to upgrade my stove situation. Normally, my stoves come from various uncle's sheds, but I am curious if there are newer stoves out that will serve me better and burn cleaner.
I have a bit of an odd situation though and have been overwhelmed trying to sort through all the options...
I have lived (and continue to do so) in a 16 ft. yurt for the past 4 years in New England. I have vinyl walls with foil-faced bubblewrap in between layers. There is almost no heat retention over time; if the stove is not going it cools to the outside temp in a couple of hours. I have an old Morso 2B which heats it up and I can get maybe 6 or 7 hours burn out of it with good wood. It does not burn any kind of clean when it is this shut down though. It has very long legs which means that the floor is always quite cold. It also has trouble heating the space behind it, I think because it is so deep and it burns more efficiently towards the front.
I am also cooking more with wood and the top is slow to heat and while it is great for water heating it is not ideal for cooking meals. I have used a Jotul 602 for cooking and been quite happy, but haven't gotten quite so long a burn and it is also not burning cleanly at all to get long burn times.
So I am interested in:
1. Small stoves with long burn time
2. Close to the ground
3. Radiate heat from the back
4. Are cleaner burning when shut down
5. Ideally have a cooking top
6. Dream stove (also has a side or back boiler for hot water)
I do not know if such a stove exists, but perhaps there are some that get closer than my current stove. Any suggestions are much appreciated. If your experience also says stick with the old Scandinavian stoves, I am open to hearing it!
Thanks in advance!
Thanks in advance!
