'Smart' on/off switch for Quadrafire Sapphire
usery
4
Edmonds, WA, USA
This probably applies to any stove with manual rocker-type on/off switch (I have a Quadrafire Sapphire nat'l gas): I want to replace the included standalone $6 Carling RS901 on/off switch with a simple setup I can control via smart plug and app (TPLink, Google Home, whatever). I'm a electrician noob but can learn (safely) and have experience building SBC's, PC's etc.
Don't need thermostat control at this time. Anyone ever do a build like this ↑ ?
Thanks!
spuldup
174
16137
Is is 120V? If so either wire it to a cord and plug it into a smart plug, or if you want to leave it hard wired, use a smart wall switch wired where it is accessible. I use a smart plug (Wyze) for a gas unit heater in my detached garage so I can turn it on remotely half an hour before working out there, but prevent operating below the lowest thermostat setting. Works great for anything that doesn't have a local "start" sequence/button.
usery
4
Edmonds, WA, USA
Thanks for the reply. My Quadrafire is stand-alone, no 120v and just a thermopile-millevolt-driven on/off switch. But I think I've solved it - bought one of these, basically a dry-contact relay with 5v power over micro-USB connector. AC adapter will go in a TP-Link smart plug and voila I can control it from Google Nest home zone. Maybe I'll figure out the voice part too.
Reactions: spuldup
spuldup
174
16137
I see, your solution will work. if you want to reduce the part count and eliminate the AC adaptor and smart plug look for a smart garage door opener switch. Dry contact and direct 120v connection.
usery
4
Edmonds, WA, USA
Thanks, good idea. I actually have another standalone stove (Dover) with similar thermopile-driven on/off - I'll try the smart garage door switch there.
Reactions: spuldup
usery
4
Edmonds, WA, USA
I looked at some smart garage door openers here - do you happen to have any specific brand or part # suggestion? I think I understand the dry-contact part (ie opener just completes or breaks the on/off millivolt circuit to stove's gas valve), but what do you mean by direct 120v connection? Would that only be in case of existing 120v on/off to stove?
thanks again
spuldup
174
16137
I've not use one and can't recommend, but this is an example that actually is powered by USB.
I mean direct connection instead of needing a smart plug.
These off-brand ones all seem to need their own app FWIW.
Looking around a bit and saw there are integrated solutions for what you want to do that aren't made for specifically garage door openers. Search "smart relay switch". That might be ever simpler.
Reactions: usery
