Smoke after pipe cleaning
Doylee4693
84
Buffalo
I took off appliance adapter and reinstalled. Is this properly installed? I used red high temp silicone at the blower outlet and appliance adapter.
So a flashlight test shows the cleanout duravent tee leaking like a siv, can I put red high temp caulk on the outside of the duravent tee where I see air escaping?? The foil tape doesnt fit well over the seem and rips
You can use high temp sealer or This tape is easier to remove later.
Reactions: Doylee4693
Its actually at a seem, and not a connection. I wont have to worry about taking it apart ever.
Oh ok then the high temp is probably the better option
It’s pretty normal for pipe to leak on startup right after being cleaned. If it’s really bad, you might not have gotten it completely clean. Those tee seams are a bugger though.
Its just at that seam,which is the only part of my duravent setup that isn’t taped. We will see, put the rtv hi temp on it this morning so have to wait until it cures24 hrs to run it again
