Smoke Detectors and Wood Stoves / Inserts
vgrund
388
Amherst, NH
I have been thinking about wood stoves and smoke detectors. It seems to me this could be a Goldilocks situation (not too near, not too far). My house, as constructed, does not have a smoke detector in the kitchen or family room (they connect in an open floor plan). I'm sure the idea at the time was to avoid false alarms from cooking (there is a smoke detector on that floor, way on the other side of the house and not in the area the diagram below). I'm planning to put an insert in the family room fireplace. Where do you have your nearest smoke detector?
Victor
  • Smoke Detectors and Wood Stoves / Inserts
In my workshop (10' ceiling), I have a combo smoke/CO detector mounted on the ceiling less than 5' away from where the stovepipe adapts to the chimney. It went off once, during my break-in fires when the stove finish was curing, that's the only time. There are code requirements that address the placement of detectors, and there are specific mounting requirements in the manufacturer's documentation which comes with the detectors. Rick
Yeah, I read some of the code requirements by Googling the topic. I didn't see any reference to wood stoves, though, just so many per floor, one in each bedroom, etc. There is room for interpretation. This arrangement must have been code compliant in 1999. I think it may be compliant with current codes, too, because we have a detector on that floor of the house and the rooms I'm asking about are not sleeping rooms. Anyway, I'm just curious about other people's setups.
No smoke detector in the living room with the stove, but there is one in the adjacent hallway. I do have a CO detector plugged in ~5 feet from the stove.
Same here, none in the LR or Kitchen, but there is one in the hallway leading to the stairs and my office. We used to have one in the kitchen, but it went off with too many false alarms.
I am going off of memory the life safety code requires a detector in each sleeping area, the area used enter a sleeping area (hallway, etc.) and one is required for each floor of the dwelling unit. When installing detectors in a house I typically installed them in the required areas, and the laundry room sometimes the utility closet (depending on size of the area). Smoke detectors can give false alarms, a lot of that depends on the technology used in the detector, I believe there are two different types. Putting one in a kitchen could definitely cause false alarms (lots of particulates in the air). Around a wood stove maybe not be the best location either.
FYI, it has been a couple of years since I have researched the required smoke detectors in a dwelling unit. So PLEASE take this with a grain of salt.
aussieblake
The big thing with smoke detectors is keeping them clean. Dirty detectors are more sensitive and tend to give false alarms more.
Attend to the batteries...false positives I can live with, but false negatives are a BAD thing. Rick
For us the false positives were boiling pots of pasta water. Triggered the units even when new. Now they are out of the kitchen.
Right on Rick. I test the units twice a year and replace the batteries with fresh ones every fall, whether they need it or not. I also like the units that beep at you if the battery is getting low.
Smoke detectors are upstairs...stove is downstairs in the living room.
One in the hallway from the living room to the bed rooms, one at the top of the basement steps and attic steps, one in the garage and one in the basement furnace room..
T
I have a smoke detector at the top of the basement stairs (stove in basement) and one in the upstairs hall way, fireplace/insert in on the main floor, about 25' from the open style foyer and staged stairway to bedrooms. I have not had a problem with false alarms. They have gone off on a few occasions, e.g., when I had a bad blow back of smoke while first lighting a fire.
I don't as they always decide to start beeping at 3am!!!
I have eight smoke detectors and three CO detectors hardwired with battery backup throughout the house. One smoke detector is only 6 feet away from the insert and only goes off when I open the door too fast with a dying/choked starting fire which rarely happens.
I have one in the same room probably 15 feet away. Went off with every fire during paint curing. But not since.
We have the same family room/kitchen layout that you have. Since I was not in the room when a grease fire set the kitchen on fire a couple of years ago there is now a detector on the ceiling dead on the line between the family room where the wood stove is and the kitchen. The only false positives come from the toaster but I am more than willing to live with that.
Kitchens burn down more houses than wood stoves by a huge margin.
Guess that's one good about being a vegetarian :). Between chimney fires and a grease fire in the past few years that's enough excitement for a lifetime!
Nah. Chimney fires used to just be part of the routine. In fact when we didn't have one it pissed me off because the chimeny was harder to clean. Grease fire setting cabinets on fire is a whole nuther animal.
Good that you made it out alright. Were you able to stop it at the kitchen?
My wife's mom had a habit of turning a burner on high and then getting distracted. When I designed the kitchen I put the cooktop with no cabinetry above or to the sides of it. I didn't want any repeat performances.
Had to go back into the inferno several times. Finally got it out with extinghishers. Took a year to clean all of that white powder out of the house. Just a few shots in the kitchen and the stuff ended up all over the house. A coating on everything. I now have a battery of extingishers and a fully charged Scott's air pack in the shed.
All happened because I turned the burner on and got a call from a customer. Whoops. Can't blame it on old age. The last time I did the same thing I was 19. Stuck on stupid I guess.
All three floors now have interconnected smoke alarms. One goes they all goes. That day I discovered that my wife can't hear the smoke alarm down stairs with the TV on upstairs. Fixed that. All hell breaks loose all over the house now. When I make toast.
My smoke detector is in a hallway leading to our bedrooms and right around the corner from the room that has the insert in it. Batteries that beep when they are low rather than plug in.
Have CO and smoke detectors in basement in oldest son's room.
Also have a separate CO detector that is plugged in with battery back up.
My units are separate due to the fact that CO hangs out down low due to it's weight while smoke heads up to the highest point due to it's being much lighter.
I also have fire extinguishers in the kitchen and the basement.....
Figure it doesn't hurt to have as much artillery as I can on board. ' Be Prepared' but HOPE we never have to put any of it to use.
:ahhh:
CO has almost the same density as air so it matters not a whit whether the detector is located high or low. The air and CO will mix and move around the house. In fact if the CO is coming from a heat source it would initially rise because it is warmer than the air low in the room.
Victor
Hi there . . . newbie here . . . well kind of, sort of. I've been lurking here for several days . . . and in the process realized that some of my on-line friends (aka Flying Cow) from other sites and neighbors (folks in Unity, Bangor and Waterville -- where I do most of my shopping) are here as well . . . so I figured I might as well join and contribute when and where possible and since fire safety is well . . . my specialty . . . figured I might as well make a comment or two to this thread.
Oh yeah, I also grew up with my parents using a hot air wood furnace in the 1970s/1980s and when I graduated from college I lived in a small camp that primarily used a woodstove for heat (early 1990s). The wood furnace provided good heat, but it was old tech and of course used a lot of wood (10-12 cords each year) to get us through the winter. The woodstove was also nice . . . but definitely over-sized for the space (it was free) . . . I ended up cooking my goldfish one day and it was not unusual for me to have every window in the place open in middle of a January snowstorm.
In any case I'm just like most other folks right now who are researching their options and getting ready to make a purchase as the price of oil skyrockets (my oil company isn't even providing a locked in price this year for their budget plan -- just stating that they will deliver oil for 5 cents below the daily cash price) . . . plus honestly I've wanted a back-up heating source in my house for some time now.
While I would love to go with an indoor gassification wood boiler down the road, at this stage of the game I'm leaning more towards a woodstove.
OK, that said . . .
In answer to your question . . . as you mentioned, positioning a smoke detector for best use can be a Goldlilocks moment . . . not too close and not too far. As mentioned by others the Life Safety Code 101 adopted by virtually every State requires smoke detectors on every level of the home (including the basement), in hallways outside sleeping areas and in sleeping areas. Those are the basics . . . it usually doesn't hurt to add in more smoke detectors . . . but there are some bad areas in the home (i.e. kitchen, laundry rooms, bathrooms, un-used attics and . . . too close to a woodstove, fireplace, etc.)
What I personally will be doing in my home is installing a smoke detector in the hall which leads to the room with the fire appliance. If there are too many false alarms I will be moving the detector a few more feet away. In either case I will be using one of the newer models that has a hush/silence feature . . . a lot of folks are unaware of these types of detectors . . . in the advent of a false alarm you can simply depress the silencer feature and the alarm will silence itself for five minutes allowing you to clear the room of the smoke, steam, burned toast, etc. After five minutes the detector resets itself -- acting as though you pulled the battery out and then put it back in . . . the only thing is you don't forget to do so . . . all automatic. These detectors can be purchased with 9-volt batteries, a 10-year lithium battery power or you can connect with AC power if your home is so equipped. A new (about 4 years old now) detector is now being sold that uses your TV remote (or stereo remote, DVD remote, etc.) to silence the detector (ideal for cathedral ceilings or high ceilings where it would be a challenge to hit the silence button.) Most of these detectors chirp every every half a minute to let you know that the detector has been silenced . . . and if the smoke/steam/etc. continues to build in the area the detector will go back into the alarm mode.
I hope this may help.
Most folks in the "business" (fire business that is) do not recommend smoke detectors in the kitchen for the exact reason you mentioned . . . way too easy to have false alarms and false alarms = people associating the noise to a false alarm.
That said . . . one detector manufacturer (which I generally like and respect) actually markets a smoke detector that states it is a kitchen smoke detector . . . even though most folks say to not put a smoke detector in a kitchen.
Partially true . . . more so if folks have photo-electric detectors . . . not as crucial with ionization smoke detectors (although it's still a good idea.)
More common is the fact that we recommend folks replace smoke detectors when they hit the ten-year mark. Studies have shown that just like everything else time tends to make things less reliable (i.e. a ten year old vehicle usually is more prone to breakdowns when used every day vs. a one year old vehicle . . . and well . . . I know I'm more prone to breaking things nowadays on myself than I was just five years ago :) ;) ). A lot of folks don't realize that they should replace their aging detectors . . . they know to change the battery . . . but don't know about changing the entire detector.
