Details
VC Defiant NC
8" SS flex insulated
Chimney is about 24' high and exterior
SW VA Location
I have had the stove for 3 years and run it almost every day in the winter. The gasket on the door started to leak so I decide to replace it. At the same time I figured I should replace the griddle gasket as well.
Door gasket went well and no longer leaks. I have installed the griddle gasket 3 times now because I keep getting smoke in the house. I do not see smoke, I can just smell it. Neither the smoke detector nor the CO2 alarms have gone off.
First gasket install I used the wire mesh wrapped gasket. I used a fair amount of cement to hold it in place. There was some leakage so I tore it out thinking that the cement got hard and was allowing air to escape.
Second time I put in new wire mesh gasket and did the minimalist approach with the cement. I just put a small dot ever 1/2 or so to hold it in place. Still got smoke in the house.
The old gasket that did not leak would come right out of the groove if I bumped it so I figured the cement was not that important
Searched the site and saw others had the same problem with the wire gasket. So I did what was suggested and went up in size a little and used non wire gasket. There is still smoke in the house.
Between all changes I removed all the old cement using a dremel with the small wire disk attachement.
I should probably add that I have ok seasoned wood. Not the best but it is pretty dry, it has sat for 1 year but not the ideal 2 years. I do not think it is wood since I have been burning the same quality of wood all along and the smoke issue was not an issue until I changed the gasket.
Suggestions?
I have never been able to get the stove to operate long term very hot. I would say my normal operating temp is around 400-450 depending on how cold it is outside. The book with the stove mentions 550-650 temps but I can only get that with the bypass open. Reading on what others have posted I figured 450 is in the realm of normal.
VC Defiant NC
SW VA Location
Suggestions?
