So here's my greenhorn question. Are you not supposed to see "smoke" if burning properly seasoned wood in an EPA stove?
Stax said:So here's my greenhorn question. Are you not supposed to see "smoke" if burning properly seasoned wood in an EPA stove?
Stump_Branch said:My neighbors assume im crazy because ill go outside at night, shine a flashlight at the chimney and stare....
RNLA said:So I'll be care full to not offend anyone. I see smoke from mine for 20-30 minutes on cold start up. Then for 5-10 minutes after a reload....
Lol, glad to hear I'm not the only one. Must be quite a shock to look out your window at 3am and see a guy in boxers and boots standing out in 5 degree temps with a flashlight aimed at the sky.Stump_Branch said:My neighbors assume im crazy because ill go outside at night, shine a flashlight at the chimney and stare....
cmonSTART said:I think I remember someone on the hearth.com forum had a webcam monitoring their chimney.
Stax said:The things you learn. Guess my neighbors have no clue what they're doing then.
Poke fun all you want. A least I was wearing boxers. LoLblades said:So you were standing out side in 5 degree temps in boxers and boots shining a flashlight into the sky, My question is DID THE LITTLE GREEN MEN MAKE A SAFE LANDING ? Or did some local volunteers help you out with a rather tight fitting jacket with extra long sleeves? Couple more questions , Have you been certified and when was your release, or is it still pending?
Sorry couldn't help myself.
BrotherBart said:I think it was back around 2005 or 2006 when a guy did have a cam aimed out of an upstairs window across the roof at the chimney.
I can't break myself of the habit. Not as often as in years past but I still go out and look at the thing every once in a while. And when I am walking back through the woods from the mailbox and see some smoke it irritates the hell out of me. "Why is that happening?" Funny since it is usually just a little bit and I used to kinda look at the steady stream of it from the old stove fondly.
The worst I have ever seen was in 2006 when I was driving down to the Englander plant to meet up with Mike. I passed a community in a valley somewhere North of there that was completely engulfed in a cloud of wood smoke. A good mile long and wide. You could see the chimney that was spitting it out from the road over the valley. My first thought was "Those folks need to go see Mike.".
gonna have to get you down for a proper tour one of these days bro. was a bad day for it when you came down last time. i still feel bad about not getting a chance to take you through the shop, heck we even have a second plant since you came down last timestoveguy2esw said:seing as your title mentions EPA stoves, the important thing to note is that with EPA stoves , the common mistake which causes smoking is to "bank" the stove too early in the coaling stage of the fire, this does not build enough internal heat to initiate the "reburning" effect. in a cat stove this can reduce the life of a cat (or plug it up) in a non-cat stove its not as likely to damage the stove but can cause creosote buildup in the flue which is not a desirable thing.
Danno77 said:Lol, glad to hear I'm not the only one. Must be quite a shock to look out your window at 3am and see a guy in boxers and boots standing out in 5 degree temps with a flashlight aimed at the sky.Stump_Branch said:My neighbors assume im crazy because ill go outside at night, shine a flashlight at the chimney and stare....
cmonSTART said:stoveguy2esw said:seing as your title mentions EPA stoves, the important thing to note is that with EPA stoves , the common mistake which causes smoking is to "bank" the stove too early in the coaling stage of the fire, this does not build enough internal heat to initiate the "reburning" effect. in a cat stove this can reduce the life of a cat (or plug it up) in a non-cat stove its not as likely to damage the stove but can cause creosote buildup in the flue which is not a desirable thing.
Hi Mike,
What exactly do you mean by "bank?"
