Hi Folks,
I am getting a strong smoky smell in the house when I use my new wood burning insert.
We just replaced an old fireplace insert that vented directly into the chimney/flue and had no connection to the chimney cap. I had that chimney cleaned, but there were years of creosote build up in the flue and some residue left over.
The new insert has a vent kit and stainless steel flex tubing connecting the insert directly to the chimney cap. The installer sealed the cap and the connections to the tubing so that we are pretty confident the smoky smell is not coming directly from burning wood, and down drafts do not seem to be a problem.
We suspect the smell is coming from the creosote residue that is left on the walls of the flue and it is gassing out as it heats up. Since the cap is now sealed, the smoky smell has no place to go except back into the home where it is creating quite a stink.
Several questions:
Does this theory sound plausible or is the smell likely caused by something else?
Will the problem get better over time as the residue eventually gasses off? How long?
Is there a way to fix it? How?
Should I try to seal the area between the insert surround and the uneven moss rock face of the fireplace? Seems like the gas has got to go somewhere though, so I am not sure sealing around the surround would help much, or would it?
Would it help to unseal the chimney cap so that gasses could escape out the chimney?
Thanks. Your suggestions/advice are greatly appreciated.
Tim
Several questions:
Tim
