So, despite what my installer insisted, I now believe I need a blockoff plate. Install of my insert (Jotul Kennebec) was in Oct 2005 with full 25' flex liner, sealed at the top. The installer told me that this was the right way to do it, but after reading here since then, I'm convinced that he was dead wrong (on more than one count, but lets start here).
My hearth is brick, and the surround isn't totally flush to the brick to begin with (1/4" gaps here and there) so between the gaps and the mortar joints, there is a lot of potential for air loss (and based on what I've seen, this potential is being realized).
I fully plan on building a blockoff plate in the spring, with several inches of ceramic fiber on top of it. After chatting with a few people with the same insert as I have, it seems like I'm not seeing the performance they are, and I'm wondering if the lack of a blockoff plate is accelerating the cooling of the insert as well. Could this be the case, or am I hearing "fish that got away" tales from other owners? Loading the stove up (not dead full, but 3-4 decent sized splits) letting everything char at about 80%, then bringing it back to 20% or so, I can see a peak of around 550 (where it'll stay for maybe 45 minutes if I'm lucky) then a gradual drop to 350 or so about 2-3 hours after loading.
The insert runs 24x7 most days (I work at home) so I'm not real keen on pulling it for a day or two while I make a permanent plate. I was wondering if it would make sense for me to get some ceramic fiber now, and shove it around the flex where it passes through the damper, as a temporary fix until the end of the burning season. I know this wouldn't stop air infiltration (which is my real problem) but I thought it may slow it down a bit. If I remove the surround (which I can do in the morning before firing the stove up, while the surface is 150 or so) I can probably pull this off with very little hassle.
On a somewhat related note, this stove allows installation with varying amounts of stove sticking out into the room. It's currently installed as far in the fireplace as possible, but when I built the hearth I allowed quite a bit of extra room so I could eventually pull it out a bit if I wanted to. Would it make more sense from a heating point of view to pull it out a bit? I'm going to have the stove out anyhow to put in the blockoff plate, so I could kill two birds with one stone if this makes sense.
Thanks for a terrific forum, I've learned a lot in the past 1.5 years.
-Hal
-Hal
We both liked the Kennebec's styling, and once we saw one in person the decision was easy. Getting used to running a new EPA stove was a bit like learning to ride a bike all over again, but this time peddling with your hands and steering with your feet though. I grew up with an old 70's stove (also an insert) and I'm not sure much of what I knew applied, short of "you light it with a match" and "you put wood in it".
