Soot Eater question
swagler85
1,195
NE Ohio
seansellsohio.com
I have a free standing stove in my house with a masonry chimney on the outside of the house. So the flue coming out of my stovemake a 90 above the stove goes into the wall and another 90 going up the masonry chimney. My question is with a soot eater can i make the 90 with the cleaning rod? There is about 1-1.5 feet into the chimney then up. Will these rods make that corner and still work? any help appreciated!
What is the ID of your thimble and the size of the chimney? My soot eater is pretty flexible, but I do not have to make a sharp 90. I wonder how the rod might wear at the touch point of the bend if it is jagged or not rounded.
Ok don't know what an ID for thimble is? Chimney is a 6 inch liner in a 24' masonry chimney
My question was poorly stated. I should have asked for the inner diameter not ID. And I was thinking about the cross section dimensions of the chimney. A small tight intersection might make it difficult to keep from wearing the soot eater rod. As the rod turns it will contact the inside corner of the thimble to chimney intersection. If that corner is smooth and rounded, the rod will fare better than if it is a sharp jagged corner.
With your dimensions, I was going to bend my soot eater rod to see if it would make the bend at all. The condition of the inner intersecting corner would then be a judgement call for you.
Ok that makes sense now (ID). Its 6" inside and a 90 so a pretty sharp bend. Good point on the corner wearing though, I could maybe rig up something to put on the edge to keep the wear down on the poles.
OK. I laid a 18" long by 6" dia thimble intersecting an 8" by 8" square flue out on the floor. My soot eater rod will make the ninety, but it takes good pressure to make it bend. I don't know how the rotation would be or the wear on the rod under these conditions. Sorry I couldn't be more definite.
Sounds the same as my basement flue. I went through the thimble but friction on the rods at the turn after it turned up the ninety put grooves in the rods all the way up. And at one point smoked my new drill. Those heavy brown rods they started supplying with the Sooteater aren't real flexible. I am going back to cleaning that flue with a brush and rope because I don't won't to damage that liner. The straight shot flue for the stove on the main floor will get cleaned with the Sooteater.
Well thanks for all the help, I think I will pass on the soot eater. Great product but I don't think my situation will work well with it.
I ended up snapping a rod when I cleaned today. It wasn't one of the white rods that came with original kit, but the black or dark brown rods that came in the add-on kit of (2) 3 ft poles. It seems to be made of a different material and like Brotherbart said is less flexible.
A few things I should have done differently:
• I forgot to use a drill/driver with a clutch. It simply bound up and then snapped it off.
• I think some of the poles had dropped down in pipe some and into stove and when I started again it just spun up the weaker poles inside firebox. The creosote fogged over the plastic so I didn't have a good view in firebox at the time. I was amazed at how the white poles survived the contorted spin but the black pole just twisted off. I think in addition to bunching it up I had reached cap and maybe that threw a little strain on it as well as it was beating around up on top.
Glad I didn't use the black poles as the first rods. Far easier for me to retrieve with it snapping at bottom. In this case just inside the firebox.
Less creosote than last year. Hopefully I can cut it in half again. I'm going to be burning douglas fir, cherry and energy logs this year.
Soot Eater question
Soot Eater question
Soot Eater question
Soot Eater question
Soot Eater question
Makes me glad that I bought 2 kits instead of 1 and the extensions.
I'm now thinking about picking up a second kit myself. I still have the second extension that would work but am now leery of using this less durable pole next year. I am sure the extensions work fine for many but they leave less chance for error if the operator, like myself, pushes it.
Both of my kits only had one of the white thin rods and the rest are the stiffer brown ones.
I appreciate the great customer service from Gardus. Timely responses and quickly sending me a replacement.
The president of Gardus even responded to me in a separate email exchange.
