I have done this. It’s pretty secure. A little movement if I really pull, but it seems tight?Try a dollar bill test on the door gasket on all sides, but focus on the hinge edge.
I've made a couple of fires with the attempt to burn overnight. Usually the glass is somewhat dirty the next morning.How big of fires are you making and is the glass staying clean?
I guess my biggest struggle right now is figuring out how to make a fire that doesn't smoke when it starts to go out? Probably related to the moisture in the wood? I still need to properly test some pieces. I split a couple yesterday and found the inside face to read around 18% I think, so I would imagine I could get a hot enough fire?How big of fires are you making and is the glass staying clean?
Osburn Matrix 2700Could be the fire is small and therefore the firebox does not reach secondary combustion temperature. Another thing to check is how well the stove is drafting. What stove make and model is this? How tall is the flue system from stovetop to chimney cap?
I use the top down method 2-3 splits of the bottom nothing bigger than a medium split. Then kindling on top all the way up to the baffle. I usually have a 2 small pieces of fat wood or chainsaw noodles that I use to light it with and a kitchen butane torch.I guess my biggest struggle right now is figuring out how to make a fire that doesn't smoke when it starts to go out?
Hard to get decent pics. How do these look? This is with the air control turned most of the way up.Could be the fire is small and therefore the firebox does not reach secondary combustion temperature. Another thing to check is how well the stove is drafting. What stove make and model is this? How tall is the flue system from stovetop to chimney cap?
![[Hearth.com] Soot near front edges? [Hearth.com] Soot near front edges?](https://www.hearth.com/talk/data/attachments/283/283799-0564b3f247ad492ea00a1a02f700760b.jpg?hash=FsEmriPDpW)
The Re-burn(secondary air) goes back to front and then makes a 180 to get to the outlet. Secondaries look good to me. How many splits were in this load?
![[Hearth.com] Soot near front edges? [Hearth.com] Soot near front edges?](https://www.hearth.com/talk/data/attachments/283/283818-f3c065ea33728b9a706fe9712aa2ecfc.jpg?hash=sWjtslbUZQ)
That looks like a pretty normal post burn, white ash, a little door haze along the edges where there roll effect to keep the glass isnt as strong.Again, very hard to get good pics. But this is what it looks like this morning. I didn’t load it overnight but did feed it into the evening. A few hot coals are left, and some discoloration on the sides.
View attachment 283790 View attachment 283791
That is good for a starter fire, but not a large fire.Hard to get decent pics. How do these look? This is with the air control turned most of the way up.
View attachment 283771 View attachment 283772
