I live in CA and we are having another year of massive wildfires. I had my chimney swept yesterday, last sweep was 12/2017. I have a spark screen installed that has the diamond shaped vent holes along with a chimney cap. The wood I used was a tree cut down from my neighbors property which I think is a type of pine, left to dry for about a year and a half.
Last night I started a fire and went outside after a few minutes to check the flow coming through the chimney even though I was told it was clean down to the metal. There were random sparks floating out, not like a fountain of sparks just a few floating by at a time. When I noticed this around February I shut the fireplace down for the season and didn't use it until last night after the cleaning, I was using wood from the same property I was using last night but dried for about 8 months at that time. I was told this is normal for extremely dry soft woods and I see other houses emitting sparks, but it made me nervous so I doused the fire instead of taking any chances (this state is a tinderbox and I live in the desert).
Can I wrap the existing sleeve with a finer steel mesh to stop the sparks from flying? I know I'll have to clean the entire system more often if I do this to keep the airflow going and keep the creosote/tar from building up.
I used a fairly large log atop a few tightly rolled pieces of cardboard and twigs, should I be using smaller logs?
This is our only source of heat at the time other than electric (which is not affordable to heat even the living room), but I also don't want to burn my house or my community down so any advice is greatly welcome. Thanks in advance!
