Split phase electric motors
SolarAndWood
6,788
Syracuse NY
I have an electric motor that is 230V 15A and is rated 5SPL hp at 3600 RPM that I used to repower a splitter with an old dead B&S;5 hp. It only has two electrical posts in addition to the ground? I wired it for 110 and it splits better than the gas motor ever did. However, I can't find anything on how to wire it for 230. Do I use the two hot legs and ignore the neutral?
  • [Hearth.com] Split phase electric motors
As the two hot leads are 180 degrees out of phase, 230 volts is the voltage measured across the two hot leads peak to peak.
I'm not an electrician, but I think you would wire the two hot leads to the motor, and ground the chassis using the ground wire.
Somebody with a little more experience with 2-phase power will probably chime in shortly.
-MG
