Got a truck load busted to add to next years stash of hickory locust poplar and sycamore.
I will snap a pic here in a bit.
Yeah i split them small. But i was hoping white did not take as long as red does to seasonIf you are going to need to burn that this coming winter, I'd make sure it's split small and in a very airy location. Oak generally should be stacked for 2 years!
Yeah i split them small. But i was hoping white did not take as long as red does to season![]()
Corey, I'd still give it at least two years. Don't get me wrong, dead oak will probably burn for you in a year, but it will most definately have water in it if it wasn't split and stacked to dry out for a while, it'll be slow to go and it will not put out any good heat. Green oak definately needs 3 years C/S/S to be good to go. I would hate to see you put that work into getting good wood and not get the optimum heat out of it....I just figured were the bark was falling off when i was handling it were it fell a while back that it would not take as long but i have more locust to get.
Actually bark falling off means very little. It is what is on the inside that causes problems.
I have a plan i just stack it some where out of the way and only use it next year if worst comes to worst but i am getting ahead. So i may not have to even try to burn it cause that red oak i went through this winter sure did throw heat for a long time and great heat.Corey, I'd still give it at least two years. Don't get me wrong, dead oak will probably burn for you in a year, but it will most definately have water in it if it wasn't split and stacked to dry out for a while, it'll be slow to go and it will not put out any good heat. Green oak definately needs 3 years C/S/S to be good to go. I would hate to see you put that work into getting good wood and not get the optimum heat out of it....
Holy sh**. I sure hope you weren't hauling that in an escalade EXTI thought you had a truckload?
Cadillac EXT's are cool but not meant for hauling wood![]()
!!Firewood has ridden in the back of my STS... more than a few timesHoly sh**. I sure hope you weren't hauling that in an escalade EXT!!
I have to take it easy on my F150 done had the frame brake once last year while towing the boat home one night long story![]()
fixed it for youCouple of weeks ago my dad and I cut a load of red oak and he tookitthe chevy to were he works and weighed it and we had almost 2 ton loaded on it
I have been hauling more locust here lately also a load of some big sycamore that is some heavy rounds.Couple of weeks ago my dad and I cut a load of red oak and he took it to were he works and weighed it and we had almost 2 ton loaded on it
I am going back for another load and more but i think im going to get some more locust first. Still got some poplar to cut up down the hill also.Looks like some nice firewood, it all adds up.
